POD problem
Leon
When I first tried POD yesterday with the POD_demo.binary program, it was OK. However, when I tried it subsequently, I got a verify error when I loaded the program, and this now happens every time. It's the same with other programs I've tried.
Any suggestions?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Any suggestions?
Leon
Does it work with F10?
Everything works fine, otherwise. I don't have any problems loading programs via the Prop Tool. It's just loading a target program with the POD debugger that doesn't work.
Leon
Leon
Paul Baker
Leon
if this problem should occur again please exit PropTerminal, disconnect your PropBoard, then reconnect it again and start PropTerminal again. I have solved it with this sequence when this problem was sometimes occured by me.
Thomas
