Anyone else spinning the Ethernet drivers?
Oldbitcollector (Jeff)
I'm curious if anyone else has tinkered with Harrison's latest Ethernet drivers?
I'm doing a re-write on the Propeller-based BBS system to support 40x23 color text.
I have the Ethernet terminal working and am in the process of reworking the BBS side.
The "api_telnet_serial" code is nearly drop-in compatible with "Full_Duplex_Serial"
Anyone playing with this?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
OBC
Before I got an EasyProp from Franz Achatz I was using a dip based enc28j60 in breadboard ... the easyprop makes it a lot easier to play ... especially as I tend to drift in/out of the ethernet stuff. Have used XPort modules for propeller based customer applications ... simplicity in itself .. negatives are of course· 1) relative cost and 2)they are a bit power hungry .. not that the enc28j60 is a miser either ..
Harrison has done a great job ... have been playing with his latest code over the christmas.
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 12/31/2007 2:38:35 PM GMT
