Cheap video LCD?
I saw this Ipod LCD screen at Costco today for $49
http://www.si5.com/products.php?pID=4025
It has video in, but I think it must use a simple composite output of the ipod:
http://pinouts.ru/Devices/ipod_pinout.shtml
So, I'm thinking this may be a cheap, portable·NTSC display...
It is widescreen 16:9 format though, which may be a problem...
I bought a cheap portable DVD player (less than $50) on sale at a local big-box store in Jakarta. Construction is pretty cheap and it balks at playing some DVDs. But that's ok, I bought it to use as a video display with Propeller. It has a 7" diagonal LCD screen with composite video and audio in, PAL only though.
One of the things that prompted me to buy it was a button on the top panel labeled "Wide"; yup - push the button and the screen switches between 16:9 and 4:3. I'm sure you can find one similar on ebaY or Amazon that's NTSC. The one I have is made by Axion, most certainly Chinese or Korean.
I've used the graphics and TV objects with it. The only problem with 16:9 format is that circles become ovals. The stretched text looks ok though, in-fact arguably better.
Regards, David
http://www.buy.com/prod/cyberhome-ch-mdp-2500r-portable-mini-dvd-player-red/q/loc/111/205020066.html
Mosquito: An animal which buzzes in your ear and never stops. He may byte you, he may nibble you, but you will know you were bit.
Technologically challenged individual, Please have pity.
http://www.geeks.com/details.asp?invtid=CH-MDP-2500B&cat=CON
It's available and only 15$ instead of 20$
I am debating on buying 2 - one to keep intact, and the other to rip apart to make a portable propeller workstation with built in battery, IR Reciever / transmitter and such.
Post Edited (OakGraphics) : 12/31/2007 5:24:22 AM GMT
Thanx
I had my wallet out before I even knew it!
Its a power hog, gets really hot.· Good picture tho.· The chineese makers actually scratch off the identification numbers on the IC's inside of the TV.· 12 volts is a bit too much to deal with in portable stuff.·
The ipod player with AV in looks like an ultra sweet deal
Post Edited (Sleazy - G) : 12/31/2007 11:27:13 AM GMT
I plan on hooking it up to the prop as soon as I find my soldering iron and hack a cable.
Then the prop can be used with anything that says a/v in?
· I just bought some nice carscreens "insignia dual screens" at best-buy ·not cheap($179 plus tax) ·but the best I could find at this time. I am only worried about resizing the new tv driver to fill this screen.
Hmm, "If you can't say something nice, don't say anything at all"
······· "No such thing as a dumb question" unless it's on the internet
········"What happens in Vegas ends up on the Internet"
