Servo spline screw size
XNOR
Hi,
What size (diameter/threads) is the screw that is used to attach the
hub/wheel to the spline shaft on the parallax continuous rotation servo?
I want to attach a thicker wheel and the supplied screw is too short.
Thanks!
Thanks!
Dave
Dave Andreae
Parallax Tech Support·
Theoretically, a 2.5mm (metric) or #3 (ANSI) type "B" tapping (e.g. sheet metal) screw would work, but virtually no one carries either size. I would be interested in knowing if others have had any luck finding screws like this outside of the hobbyist marketplace.
