Dose AnyOne have a Radio Shack Digtal Multimeter CAT # 22-812 UpDate i got it w — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2007-12-20 02:09 in General Discussion
Hi EveryOne
I just bought this meter yesterday and hook up to my desk top computer and it works great
Then let see if i can get it to work on my lap top· computer and it will not
·I try 2 other USB to Serial adpters and even the one that I have for my Basic Stamp no good will not work
Can anyone tell me if there is a USB adpter that act more like a normal serial port
··Thanks for any·idea.gif·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 12/20/2007 2:12:57 AM GMT
    edited 2007-12-19 04:21
    The Parallax USB-to-Serial adapter with the FTDI VCP driver does exactly that.
    edited 2007-12-19 15:29
    JonnyMac
    Thank you for your reply
    I try this and it·would not work
    I have not try with the· FTDI VCP driver· yet but i will give it a try
    Is there any other type that i can try that will work
    I have mess up the drivers for·USB adapter·now I·can not·program my Basic
    Stamp any more with the lap top
    so i going to use the remove tool and reinstall the drivers and see if
    i get it working again
    http://forums.parallax.com/showthread.php?p=644148
    Sam
    Post Edited (sam_sam_sam) : 12/20/2007 2:22:12 AM GMT
    JonnyMac
    Thank You For your help those drivers did the trick on the Parallax USB Adapter and the FTDI VCP driver
    Now i got my Meter TO WORK on my lap top but had to change from 9600 to 4800
    The problem with the Basic Stamp Test Board that i have
    How trouble shoot this was i use another Basic Stamp board that i have and that one works
    Now i found why my other·Basic Stamp board the i was talking about· above dose not work when i soldier the serial port plug i did not solider the two holding pins so now there must be one or more·pins broken·because the plug move a lot more then it did
    Sam
    Post Edited (sam_sam_sam) : 12/20/2007 2:18:08 AM GMT
