HSS Sound Envelope Editor — Parallax Forums
ColeyColey Posts: 1,130
edited 2007-12-18 12:11 in Propeller 1
Hi
I've been helping Baggers with the SoundFX for his Frogger conversion (Nice work Baggers!)
We are using the excellent HSS drivers see http://forums.parallax.com/showthread.php?p=604722 for more info.
Whilst designing the sound fx I threw together this quick and dirty envelope editor app to speed things up a little.
Presently it doesn't support the optional extra 16 Bytes of FM sequenced data but I can add it easily enough if there is any interest in it.
It's set for Hybrid defines but can easily be adapted for other boards....tongue.gif
Coley
  • JT CookJT Cook Posts: 487
    edited 2007-12-18 02:10
    I haven't downloaded this tool yet, but I was thinking about making something similar instead of using the guess, load, and listen method, which really sucks and is really time consuming.
    One thing I have noticed is that HSS will sound different on the Hybrid then on the Hydra or Demo board because I believe it is hard configured for 80mhz and the sounds run at a higher pitch at 96mhz.
  • Ym2413aYm2413a Posts: 630
    Yeah, I'll convert it over to the Hybrid tonight, this way it has the correct timing and freq. [noparse]:)[/noparse]
