Spin stamp pins
This has been on my mind for a while.
On the spin stamp, it says DO NOT CONNECT for the pins normally used for programming on a basic stamp 2, even though the diagram clearly shows that these pins are connected to the propeller chip. So...
a) Will it matter if I connect this to the professional development board, or will I end up burning something out?
and
b)If these pins are connected to the microcontroller, what do they do?
and
What about connecting it to a PDB or BOE?
Paul Baker
I tested it on my system with both a Board of Education rev.C (usb) and
a Javelin Stamp demoboard (serial). In both cases (lucky me) ·I receive the expected
output in a Basic Stamp IDE debug window. This debug window lets
you toggle the DTR which resets the spin stamp. After reset
the program stored in the spin stamp eeprom is restarted.
regards peter
Post Edited (Peter Verkaik) : 12/15/2007 1:37:37 PM GMT
