Optical interrupter
I am trying to figure out how to use this optical interrupter I have, but I cannot figure how to hook it up correctly.
I found a data sheet http://www.fairchildsemi.com/ds/H2/H21LOB.pdf
I tried hooking it up like this
But I get 5v on Vout regardless if it is being interrupted or not. Any advice?
5v
1 -5v--/\/\/\----| |-------(3)------------------|
| |--------(4)----------------------------- signal out
2 --gnd---------| |--------(5)------gnd
What i would do is use·the test circuit That on the data sheat and se what happens·if this will work for you
From the look of it you can not just hook a volt meter to the output pin only from what i can see from figure 9 on the data sheat this at the bottom of the data sheat
I hope that this will help you
Figure 9. Switching Speed Test Circuit
R 1 = 300Ω
R 2 = 180Ω
C 1 = 15pF
C 2 = 20pF stray wire capacitance
C1 and C2 include probe and
··Thanks for any·
Sam
I am glad that you got it working
··Thanks for any·
Sam
