Optical interrupter — Parallax Forums
Optical interrupter
Vertex78Vertex78 Posts: 51
edited 2007-12-14 16:09 in General Discussion
I am trying to figure out how to use this optical interrupter I have, but I cannot figure how to hook it up correctly.
I found a data sheet http://www.fairchildsemi.com/ds/H2/H21LOB.pdf
I tried hooking it up like this
                                                              5v
1 -5v--/\/\/\----|  |-------(3)------------------|
                       |  |--------(4)----------------------------- signal out
2  --gnd---------|  |--------(5)------gnd
But I get 5v on Vout regardless if it is being interrupted or not. Any advice?
    edited 2007-12-13 22:18
    ·Vertex78
    What i would do is use·the test circuit That on the data sheat and se what happens·if this will work for you
    From the look of it you can not just hook a volt meter to the output pin only from what i can see from figure 9 on the data sheat this at the bottom of the data sheat
    I hope that this will help you
    Figure 9. Switching Speed Test Circuit
    R 1 = 300Ω
    R 2 = 180Ω
    C 1 = 15pF
    C 2 = 20pF stray wire capacitance
    C1 and C2 include probe and
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
  • Vertex78Vertex78 Posts: 51
    edited 2007-12-14 13:22
    my problem was I was using to big of a resistor for the diode side, I guess I was not letting enough current flow through it. It works now the way I expected it to.
    Vertex78
    I am glad that you got it working
    Sam
