Why does the Prop come in a fat PDIP instead of a narrow PDIP? — Parallax Forums
RaymanRayman Posts: 15,886
edited 2007-12-08 04:43 in Propeller 1
Anybody know?· I think I would greatly prefer a narrow PDIP body...· I think I read that the silicon is 1 mm^2, so I think it would fit..
  • parts-man73parts-man73 Posts: 830
    edited 2007-12-08 00:49
    I'm not sure that I've ever seen a narrow 40 pin DIP.
    I'm sure someone will immediately post a picture of some obscure chip to prove me wrong but.....
    Brian
    uController.com - home of SpinStudio
    PropNIC - Add ethernet ability to your Propeller!
    SD card Adapter
  • RaymanRayman Posts: 15,886
    edited 2007-12-08 00:56
    I guess that explains it, such a thing doesn't exist... Maybe it's a mechanical problem with something that long...
    edited 2007-12-08 01:01
    Besides that, I think the die is too big to fit in a 0.300" wide package.
  • kittmasterkittmaster Posts: 77
    edited 2007-12-08 01:03
    As a semiconductor engineer, typically when you have that many connections to the die, the bond wires become very unrully. It would be very difficult to have a narrow package with that many bond wires in any type of narrow package config.
    Also the die gets larger as well and most likely won't sit in a narrow carrier properly. Even 28 pin devices tend to expand in width, like 32's etc etc
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2007-12-08 03:22
    Phil is correct...
    The current Propeller die is·almost 6mm square or .42inches ... it would be physically impossible to use a .3 inch dip
    kittmaster,
    I've seen that many connections on a single chip in a .3 inch, but special tooling was required, since the die was actually oriented 45 deg inside the DIP package.· It's not common.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 12/8/2007 3:27:46 AM GMT
  • mosquito56mosquito56 Posts: 387
    noobs alive and well thanx
    Mosquito: An animal which buzzes in your ear and never stops.
