Parallax USB to Serial (RS-232)
Hello,
I'm Tiago Rodrigues and i have a Parallax USB to Serial (RS-232)
Adapter and they recomend this FTDI drivers.
(http://www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/Level/a/ProductID/378/Default.aspx?SortField=ProductName,ProductName)
The problem is that i have windows vista on my notebook (and it is not
windows xp compatible) and i can't totally access to the COM port.
In the Basic Stamp Dev program i can access the COM1 port and program
the BS2, but when i use Java Eclipse i can't the port dues not appear
in the port list.
The problem its not in the source code because i tested it with the
same usb2rs232 adapter in a friend PC with windows xp, and all work
great..
i maybe have some drivers incompatibility problem with vista, or bad
configuration, but i really have made all equal in the win xp and work
good there.
There are more people with this problem? Can you help me out?
Thanks for the time,
TigPT
Tiago Rodrigues
Post Edited By Moderator (Chris Savage (Parallax)) : 12/5/2007 6:27:58 PM GMT
in the port list.
great..
good there.
TigPT
Tiago Rodrigues
Look here: www.ftdichip.com/Drivers/VCP.htm.
yes i have last drivers installed, the ones that say that are for vista.. it works fine with BASIC Stamp Editor v2.3.9 but i can't "see" the com port with java..
anyone have the same problem?
