Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Serial Camera - Page 2 — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
Serial Camera
1
2
Rayman
15,960
2007-11-27 03:10
edited 2007-11-27 03:10
Look here:
http://www.rayslogic.com/propeller/Programming/Cameras/cameras.htm
Christoph
13
2008-03-01 14:00
edited 2008-03-01 14:00
Hi,
has anyone continued work on the C-328?
With the help of Rayman's and Harrison's code examples I just started on my cam.
But after making just one picture
it stopped syncing for good.
I was already
suspecting some fatal event in my cam
but when connecting an oscilloscope there was
suddenly
an output from the cam's
tx pin. The cam SYNCed and made a picture. As
soon as the oscilloscope was detached function ceased. So I put a 22k resistor across
the cam's tx pin and Vdd and it is now working ... most of the time. But
not
always.
Has anyone got the same problem and solved this?
Does the Eval board give any clues (I haven't got it)?
Is it a problem of too long wires? I left the cable's length at 30cm as it was shipped.
Does anyone know where to download the evaluation software (C328Ap.exe)? I couldn't
find it on COMedia's web site.
Thank You,
Christoph
Rayman
15,960
2008-03-01 19:54
edited 2008-03-01 19:54
What baud rate are you using? I really only had luck at 115200...
Christoph
13
2008-03-01 20:00
edited 2008-03-01 20:00
Rayman said...
I am using 115200 Baud as well.
Christoph
J.P
1
2008-09-18 17:25
edited 2008-09-18 17:25
Hi, im using the C328-7640 aswell but havent got it
even to respond to my sync
all i get back is the same
byte array
i send to the camera 170 13 0 0 0 0.
could anyone please supply some code help in C# if possibly?
thank you in advance!
Sniper King
221
2008-09-18 21:33
edited 2008-09-18 21:33
How fast can you move a 640x480 image to the SD card?
- Ouch, thats not suppose to be hot!
Michael King
Application Engineer
R&D
Check out
Project: PSAV
Persistent Sailing Autonomous Vehicle
1
2
Sign In
Register
to comment.
But after making just one picture·it stopped syncing for good.·I was already
suspecting some fatal event in my cam·but when connecting an oscilloscope there was
suddenly·an output from the cam's·tx pin. The cam SYNCed and made a picture. As
the cam's tx pin and Vdd and it is now working ... most of the time. But not always.
Thank You,
Christoph
Christoph
·- Ouch, thats not suppose to be hot!··
Michael King
R&D
Check out Project: PSAV Persistent Sailing Autonomous Vehicle
