JTAG Programming using a BASIC Stamp
I want to program a Xilinx CPLD with a BASIC Stamp.· It seems like a pretty easy interface which uses a Clock, Data_In, Data_Out, and a Mode_Select signal.
From what I have read, the·device (CPLD) reads·Data_In on the rising edge of the Clock, the device puts Data_Out on the falling edge of the Clock.· The Mode Select determnes how the device will interpret the data.
Does anyone have experience with using the JTAG (TAP) interface with a BASIC Stamp?· Coule the SERIN and/or SEROUT functions be used?
Bob
Bob
SERIN/SEROUT will NOT work for this kind of application as you have synchronous serial communication, not asynchronous serial communication. SHIFTIN/SHIFTOUT may do the trick for you.
Bruce Bates
Bob
