Using 2 EEPROM's with propeller. — Parallax Forums
DavidMDavidM Posts: 640
edited 2007-11-13 13:12 in Propeller 1
HI,
I would like to use 2 EEPROM's with the propeller. ( this is for salable production)
EEPROM-1, As the normal EEPROM for spin code
EEPROM-2, As extra memory to store a unique SERIAL NO , parameters and some user data ( not much under 1-2k)
I understand these are both on the I2C bus, I also have a LCD display that is using the same I2C bus.
Q1) When I load spin code to the eeprom ( via spin) , does the propeller IGNORE the second eprom?
Q2) Do I just parallel wire these as normal? ( i.e SCL, SDA wired in parallel)
The reason I want to do this is to update firmware and not have to worry about the serial no and user settings/data.
Q3) Is this a valid approach?
I believe I can get small EEPROM's quite cheap.
regards
Dave M
  • LeonLeon Posts: 7,620
    edited 2007-11-13 09:53
    You could also use one of those little Dallas 1-wire devices.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • DavidMDavidM Posts: 640
    edited 2007-11-13 09:58
    Hi Leon,
    I was think of just using one of these 24LC04B from microchip for under a dollar! And I need to use the I2C bus.
    I am not sure of the chip you are suggesting?
    Dave M
  • Nick MuellerNick Mueller Posts: 815
    Or just a bigger EEPROM?
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
  • simonlsimonl Posts: 866
    edited 2007-11-13 10:03
    Hi David,
    Although I've not done any of this personally; I believe the answer to all of your questions is yes!
    Leon & Nick also have valid approaches; probably the simplest is to use a bigger EEPROM - that'd be the same as what's done on the ProtoBoard, which has 64K. I'm sure there are several objects that will enable use of bigger EEPROM (as well as multiple EEPROMs).
    HTH.
    Cheers,
    Simon
    www.norfolkhelicopterclub.co.uk
    You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
    BTW: I type as I'm thinking, so please don't take any offense at my writing style smile.gif
    edited 2007-11-13 10:04
    Hi Nick,
    yes I can use a bigger eeprom, But once I administer a serial number I don't want to loose it , and I need to change the firmware if needed, I would expect to have hundreds of EEPROM's to update, I would have to manage the uploading of the spin to the propeller and make sure it does not write over the serial /user data. I also dont know how large my program is going to be yet!
    To me, it would be easier to use two eeproms.
    Dave M
    edited 2007-11-13 10:05
    David,
    So long as your data / S/N, etc are above 32K it should remain - even after re-programming.
    Cheers,
    Simon
    edited 2007-11-13 10:08
    Hi Simoni,
    You have a valid point! So I gather that 32K is the maximum that spin can use for a program?, I mean can I still address more than 32K with data?
    Dave M
    edited 2007-11-13 10:25
    Yup, you can access the EEPROM above 32K - not sure if there's a limit to how far you can go, but 64K is definitely doable [noparse]:)[/noparse]
    As I understand it; the IDE downloads the full 32K - whether your program uses it all or not (I'm sure someone'll correct me if I'm wrong!). So, as long as your non-volatile data is written above the first 32K it will remain.
    <edit>
    Just to clarify; your program will need to use one of the I2C objects to put the non-volatile data above 32K. I don't think there's any way to get it there otherwise...
    </edit>
    Cheers,
    Simon
    edited 2007-11-13 10:35
    Thanks Simoni,
    I think I will just use 1 EEPROM!
    regards
    Dave M
  • AleAle Posts: 2,363
    edited 2007-11-13 11:06
    most I2C devices have extra pins to change the address. The propeller will read the device with a specific address (external A0..2 = 0), if you use the address 001b for te second EE, that will make it not active when the propeller reads the address 000b, as you would expect.
    edited 2007-11-13 11:26
    HI Ale,
    I was wondering how different I2c devices get their address, I gather its done with pins?
    thanks
    Dave M
    edited 2007-11-13 11:44
    If they are the same part number, they have a specific address and sometimes pins to select low weight address. Have a look at the 24lc256 datasheet:
    pdf1.alldatasheet.com/datasheet-pdf/view/74858/MICROCHIP/24LC256.html
    In the first page you se that pins 1,2 and 3 correspond to the addresses A0, A1 and A3. The base address for this device can be seen in page 6 of the same datasheet, and how it is formet (0xa0 + A3A2A1b).
    I hope is clear (ask if not). Some I2C devices does not have extra pins for addresses so you have to have one bus per device.
    Have fun
    edited 2007-11-13 11:48
    Thanks Ale
    Dave M
    edited 2007-11-13 12:11
    Different devices have different base-addresses (cast in silicon). Sometimes, the address can be selected with a different part-number (especially if it doesn't have address-pins).
    So having more than one device on I2C, it is best to watch out for conflicts in the addresses (and maybe set a different address with the pins and/or the part).
    Nick
    YADRO
    Ja Nick, you are right I forgot about the variations in part numbers, I think Microchip's I/O expanders are of this kind, or where ADCs ?, fuzzy memory of mine now smile.gif
