Using 2 EEPROM's with propeller.
DavidM
HI,
I would like to use 2 EEPROM's with the propeller. ( this is for salable production)
EEPROM-1, As the normal EEPROM for spin code
EEPROM-2, As extra memory to store a unique SERIAL NO , parameters and some user data ( not much under 1-2k)
I understand these are both on the I2C bus, I also have a LCD display that is using the same I2C bus.
Q1) When I load spin code to the eeprom ( via spin) , does the propeller IGNORE the second eprom?
Q2) Do I just parallel wire these as normal? ( i.e SCL, SDA wired in parallel)
The reason I want to do this is to update firmware and not have to worry about the serial no and user settings/data.
Q3) Is this a valid approach?
I believe I can get small EEPROM's quite cheap.
regards
Dave M
regards
Dave M
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I was think of just using one of these 24LC04B from microchip for under a dollar! And I need to use the I2C bus.
I am not sure of the chip you are suggesting?
Dave M
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Although I've not done any of this personally; I believe the answer to all of your questions is yes!
Leon & Nick also have valid approaches; probably the simplest is to use a bigger EEPROM - that'd be the same as what's done on the ProtoBoard, which has 64K. I'm sure there are several objects that will enable use of bigger EEPROM (as well as multiple EEPROMs).
HTH.
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
yes I can use a bigger eeprom, But once I administer a serial number I don't want to loose it , and I need to change the firmware if needed, I would expect to have hundreds of EEPROM's to update, I would have to manage the uploading of the spin to the propeller and make sure it does not write over the serial /user data. I also dont know how large my program is going to be yet!
To me, it would be easier to use two eeproms.
Dave M
So long as your data / S/N, etc are above 32K it should remain - even after re-programming.
Cheers,
Simon
You have a valid point! So I gather that 32K is the maximum that spin can use for a program?, I mean can I still address more than 32K with data?
Dave M
As I understand it; the IDE downloads the full 32K - whether your program uses it all or not (I'm sure someone'll correct me if I'm wrong!). So, as long as your non-volatile data is written above the first 32K it will remain.
<edit>
Just to clarify; your program will need to use one of the I2C objects to put the non-volatile data above 32K. I don't think there's any way to get it there otherwise...
</edit>
Cheers,
Simon
I think I will just use 1 EEPROM!
regards
Dave M
I was wondering how different I2c devices get their address, I gather its done with pins?
thanks
Dave M
pdf1.alldatasheet.com/datasheet-pdf/view/74858/MICROCHIP/24LC256.html
In the first page you se that pins 1,2 and 3 correspond to the addresses A0, A1 and A3. The base address for this device can be seen in page 6 of the same datasheet, and how it is formet (0xa0 + A3A2A1b).
I hope is clear (ask if not). Some I2C devices does not have extra pins for addresses so you have to have one bus per device.
Have fun
Dave M
A bit more complicated to make things easier.
Different devices have different base-addresses (cast in silicon). Sometimes, the address can be selected with a different part-number (especially if it doesn't have address-pins).
So having more than one device on I2C, it is best to watch out for conflicts in the addresses (and maybe set a different address with the pins and/or the part).
Nick
YADRO
