Protection diodes in relay applications
Hi all,
I'm pretty new to electronics.· I've been told by many people (including the instructor of an electronics course I'm taking) to use a diode to protect my chips from the reverse voltage from a relay.· They also tell me to use a fast one, but I've not heard any specific recommendations.· I want to use my SX chip to run a relay, small pc board mount one, does anyone have any kind of an idea what one I should start with?· Or perhaps some specs?
Russ
Russ
If your relay is a mechanical one, a 1N4148 works well for me although others like the 1N4001 or 1N4004 for higher currents. Solid state relays normally dont require a diode....Radio Shack should have these....
Twisted Pair....
Twisted Pair....
I think you'll find just what you're looking for in one of the documents on the Parallax website. It works great with the SX28 chip!
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv6.pdf
Hope this helps,
Robert
Twisted Pair - a 1N4001 - is not really suitable for this purpose with a Vrrm of only 50v !!
I have attached a data sheet ...
John Twomey
'Necessity is the mother of invention'
Some other sugestions:
- Use a driver IC like the ULN2803. These are eight Darlingtons in a single chip. Each will handle a five hundred mA. They also have the protective diode built in.
www.st.com/stonline/books/pdf/docs/1536.pdf for the -2803.
- Get a relay with the diode built in.
Here's a page from Digi-Key: search.digikey.com/scripts/DkSearch/dksus.dll
This page is a list of small signal relays that contain the suppression diode. These are various contact/power combos.
Happy hunting! 'Luck on your project!
kenjj
Just thought that a nudge in the right direction would help but it turns out that I learned something as well. Thanks for the help. Speaking of help QuattroRS4, can you take a look at my recent post regarding a source for servo pots ? I need Help. I've been pulling hair out trying to locate one of these....I'm almost bald now. Sorry for invading your post Professorwiz....
Twisted Pair....
Well, maybe next time. *sigh*
kenjj
Johnnymac, that does simplify things for me, using a transistor.· I've just bought the incorrect relays - 12v but have a whole reel of 3904's so I'll just go 12v and use the transistors and diodes.·
Robotworkshop, thanks, I just never am able to find exactly what I'm looking for in the huge amount of info on the web site here!· Not that it's a bad thing.·
Thanks again.
Russ
Never give up when things go wrong.
robosapienv2-4mem8.page.tl/
