Adopted TODDLER Problems
Hi All,
I just adopted a old TODDLER and in doing so downloaded and wrote the code "first steps" to the BS2.
Here are the things I have done thus far.
- it powers on
- BS2 editor verifies the stamp and successful code download
- batteries new
- servos are connect to the correct ports
- disconnect the mechanical linkage from the servos in case it was binding
But my adopted TODDLER does not even thing of moving. Any suggestions out there ??? The book I received with it really doesn't have a meaty trouble shooting guide.
Cheers,
Glen
It has 3 positions.
1) Off
2) Power to the main board, but not the servos
3) Power to main board and servos
First, check to see if it's on the setting for power
to the main board and the servos.
humanoido
I tried the procedure of holding down the reset while going from position· 2 to 3. From what I have read this should allow the code to execute, correct ?
g.c.
One of the switch positions will power on the servos.
A program will normally execute upon power on
without reset. Check the servo wires, and check to
confirm servos are receiving power.
humanoido
Check the power line for 6 volts with the slide switch
moved into the power position for the board and servos.
An oscilloscope is not needed for this step.
humanoido
[noparse][[/noparse]Tim]
"Place a jumper wire between the Vs1 and Vss above the breadboard.· Place another jumper wire between Vs2 and Vss on the same header.· This connects the servo grounds to the Basic Stamp's ground."
