Pins on the PSC — Parallax Forums
Pins on the PSC
rockerboyrockerboy Posts: 14
edited 2007-11-10 22:37 in General Discussion
Hi,
In the above picture, what do the pins W, R, B mean on the PSC? If I want to use a MAX232 converter instead of the above circuit, which pins of the PSC should I connect to the MAX 232?
Post Edited (rockerboy) : 11/9/2007 12:18:03 AM GMT
  • JonnyMacJonnyMac Posts: 9,554
    edited 2007-11-09 01:37
    W = white (signal), R = red (+5 vdc), B = black (ground)
    edited 2007-11-09 02:15
    You are going to have some problems with the MAX232 since it's designed for a full duplex connection (one line in each direction) while the PSC is half duplex and it sends/receives in both directions using the same line. You could use a combination of both circuits with the transistors converting the half duplex connection into a full duplex connection, but the MAX232 doing the conversion to RS232 voltage levels. Because the MAX232 inverts its signals, you'll need another inverter or another pair of transistors to serve the same purpose.
  • rockerboyrockerboy Posts: 14
    edited 2007-11-09 07:40
    Mike Green said...
    Thanks Mike. I'll try that out.
    Hi Mike,
    I'm trying to send some commands to the PSC through the serial port using Teraterm (including "!SC" in ASCII). I have used the above circuit diagram. So far the servos are not moving. Do you know what might be wrong? I have tried with 2400 and 9600 baud rates, but both aren't working.
    Also, do we need a cross over cable?
    rockerboy
    Post Edited (rockerboy) : 11/10/2007 10:53:45 PM GMT
