Pins on the PSC
In the above picture, what do the pins W, R, B mean on the PSC? If I want to use a MAX232 converter instead of the above circuit, which pins of the PSC should I connect to the MAX 232?
Post Edited (rockerboy) : 11/9/2007 12:18:03 AM GMT
I'm trying to send some commands to the PSC through the serial port using Teraterm (including "!SC" in ASCII). I have used the above circuit diagram. So far the servos are not moving. Do you know what might be wrong? I have tried with 2400 and 9600 baud rates, but both aren't working.
Also, do we need a cross over cable?
rockerboy
Post Edited (rockerboy) : 11/10/2007 10:53:45 PM GMT
