What happens when a screwdriver smacks a Sensirion SHT11 temp/humidity sensor??? — Parallax Forums
uxoriousuxorious Posts: 126
edited 2007-11-09 20:54 in General Discussion
I found out today. Here's a pic through a microscope of the innards of a Sensirion SHT11. Still works........I will glue the cap back on if I can find it.
~~ dRu ~~
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2007-11-08 22:48
    dRu-dRu said...
    Answer: you make SH1T out of it ... LOL
    Hmm - did you get upset with it ? or was it accidental ? .... Have done both myself ... not the same component though ! lol
    Rgds,
    John
    'Necessity is the mother of invention'
  • uxoriousuxorious Posts: 126
    Fortunately it's on a crossbow mote that is being used as a gateway for testing other crossbow nodes, so the sensor isn't being used on that board. The crossbow mote is a public UC Berkeley design of a wireless sensor module that transmits temperature, humidity, light level, and other sensor obtained data across a 2.4ghz mesh network using the TinyOS operating system.
    www.xbow.com/Products/productdetails.aspx?sid=252
    A really cool example of these wireless sensor modules is at a Napa Valley vineyard:
    camalie.com/WirelessSensing/WirelessSensors.htm
    ~~ dRu ~~
