Why is reload required to run? — Parallax Forums
verobelverobel Posts: 81
edited 2007-11-08 16:15 in General Discussion
Fellow SXers;
I have wired up the SX/B clock example on the PDB (using SX/28) and run the TIMER.SXB program from the examples. It works ok except that whenever I turn off the PDB board and then turn it back on, I have to download the program in order to make it run. Is this normal?· Shouldn't the program stay in memory and start running on powerup?
John
  • JonnyMacJonnyMac Posts: 9,768
    edited 2007-11-08 16:10
    Do you have resonator plugged into the PDB? If you're using the Key to provide the clock that will be lost when the Key looses power.
  • verobelverobel Posts: 81
    No. I have plugged it in now and that has fixed the problem. Thanks, John
