FullDuplexSerial Rx coding question and the uOLED-96
Good Evening,
I was having problems monitoring Tx outgoing serial data on my scope untill I changed to PLL8X and everything started reading fine. I need a little help using the Rx method, I would like to recieve a byte of· data, store it in·the varible Byte_Recieved and then jump to a paticular OBJ based on the byte recieved. I am using pin 21 as my recieve line and 20 for Tx. How is the best way to represent data coming into the OLED-96 ? And is all data in ASCI until interpeted differently ?
JMLStamp2p
John.
My code so far:
{{OLED_Transmit_Test.spin}}
CON
· _CLKMODE····· = XTAL1 + PLL8X·······················
· _XINFREQ····· = 8_000_000
· dSlow········ = 50
· dFast········ = 20
OBJ
· OLED· : "uOLED-96-Prop_V4"
· DELAY : "Clock"
· DATA : "FullDuplexSerial"
VAR
· long Stack [noparse][[/noparse]9]
· byte Byte_Recieved
PUB MAIN
· DELAY.Init(8_000_000)
· OLED.InitOLED
· OLED.CLS
· REPEAT
··· Transmit
··· Recieve
PUB Transmit
· data.start(21,20,%1000,9600)················ 'rx pin = 21 : tx pin = 20 : mode : baud rate
· data.tx(1)
· delay.PauseSec(2)
· data.tx(2)
· delay.PauseSec(2)
· data.tx(4)
· delay.PauseSec(2)
· data.tx(8)
· delay.PauseSec(2)
· OLED.PutPixel(46,30, 0,255,0)····················· ' Put a GREEN pixel at x:0, y:63
· DELAY.PauseSec(1)
· OLED.CLS
· DELAY.PauseSec(1)
'Need help here.
PUB Recieve
·REPEAT
· data.start(21,20,%0001,9600)··············· 'Check mode bit(4), echo off on Tx
· data.rx·························································· ' ???
· If Byte_Recieved := (01)
·· Pixels·····························································' Jump to OBJ Pixels if data recieved was (01)
· If Byte_Recieved := (02)
·· Rectangles
JMLStamp2p
John.
My code so far:
CON
OBJ
· DELAY : "Clock"
VAR
PUB MAIN
· OLED.InitOLED
· OLED.CLS
· REPEAT
··· Transmit
··· Recieve
PUB Transmit
· data.tx(1)
· delay.PauseSec(2)
· data.tx(2)
· delay.PauseSec(2)
· data.tx(4)
· delay.PauseSec(2)
· data.tx(8)
· delay.PauseSec(2)
· DELAY.PauseSec(1)
· OLED.CLS
· DELAY.PauseSec(1)
'Need help here.
PUB Recieve
·REPEAT
·· Rectangles
Data is received (as it is transmitted) as a sequence of byte values. If you want them to be readable ASCII characters, you have to provide for that. For transmitting, you can use the dec / hex / bin / str methods. For receiving, you can use the Extended FullDuplexSerial object to process the received data for you (somewhat).
The uOLED-96-Prop requires PLL8X for proper operation and a crystal frequency (_XINFREQ) of 8MHz.
I just need help with the Spin coding for the Rx method as far as saving the incoming byte in the varible (Byte_Recieved). If you would please look at the PUB Recieve method below, I want to compare the incoming Recieved Byte and Jump to the method Pixels if I have recieved a (1) or Jump to method Rectangles if I have recieved a (2). I used the Tx method just to monitor the transmission to make sure that _CLKMODE = XTAL1 + PLL8X was going to work for me. All I want is to run PUB Recieve in a loop, test the incoming Byte and jump to a paticular method based on the Byte recieved.
Thanks again for your advise,
JMLStamp2p
CON
_XINFREQ = 8_000_000
dSlow = 50
dFast = 20
OBJ
OLED : "uOLED-96-Prop_V4"
DELAY : "Clock"
VAR
byte Byte_Recieved
PUB MAIN
OLED.InitOLED
OLED.CLS
PUB Recieve
REPEAT
data.rx
Byte_Recieved := data.rx 'Please adjust this code if not correct ...
If Byte_Recieved := (1)
Pixels
If Byte_Recieved := (2)
Rectangles
If (Byte_Recieved == 1)
Pixels
If (Byte_Recieved == 2)
Rectangles
You have to use "==" for compare, ":=" to set/equate. Takes some getting used to.
Adoy
One's true identity can only be learned through reflection.
You do need to use the code brackets so that the message editor doesn't adjust the spacing:
