IDE upgrade hassle
One complaint that I've always had, but kept to myself until now.
When upgrading the Propeller tool software. Why does it create a new folder and a new desktop icon and leave the old version in place?
I would much rather see it overwrite the current version, so that my code is in the correct folder in relation to the Propeller Tool, and the the file type associations are automatically re-associated to the newest version.
Or better yet, put an option right in the Propeller tool to "Check for Updates" and the ability to update the Propeller Tool without downloading and manually installing.
I only mention it here, instead of an email to Parallax because... Maybe there is a very good reason for the current upgrade path. Am I the only person that this annoys?
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Brian
SD card Adapter
> version in place?
Did it ever happen to you that a new version of some software also has new bugs?
Not that I think a new Propeller tool will have some ...
a) it is not whise to switch compilers during a project
b) it is not whise to assume that new versions work with old sources.
c) if you don't think a) and b) is true, you'll learn the hard way
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
I always overwrite the previous version. Just change the destination path to something YOU choose {like
