HB-25 Question
Bill Chennault
Chris and All--
Is there an internal connection between VSS and the metal frame of the HB-25?
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
You are right, I could and can. I was taking the easy way out trying to get Chris to tell me exactly how the grounds are tied together internally to the HB-25 and then if they are tied to the frame. I definitely do have continuity between the frame and ground, which I do not really want.
I SUPPOSE I could cure this by setting my two HB-25 output pins (one per HB-25) to input pins right before I end the program?
--Bill
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
I thought of that. I think it is a good solution. However, I would still like to know the grounding situation within the HB-25.
Thanks for the idea! (In fact, setting the output pins to input just before ending the program AND insulating the HB-25s from the frame might be the best idea.)
--Bill
I see you have your answer already, but yes, if you look at the HB-25 – (minus) input (which is ground) you will see a trace going to one of the Swages that mount the board to the Heat-sink/Fan. Take care.
Chris Savage
Parallax Tech Support
Thanks!
--Bill
