String problem or data type problem ?
I need to know what data type this needs to be to correctly display. I am basicaly taking a temp reading and displaying it on my 2x20 lcd screen. The last line of code is were i get the compile error....
I get a compile error because i am not addressing the data type or something?
Help please
{{ Demo LCD
Uses LCDDEMO Version 1.2
Uses ADC0831 with Lm34 as a temp
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
esc = $1B 'Escape code
cr = $0D 'Carriage Return code
lf = $0A 'Line Feed code
eos = $FF 'End of string code
eog = $FF 'End of graphics code
space = $20 'Space character code
var
byte lm34temp, temp
OBJ
LCD : "LCDDEMO"
pub main
repeat
dira :=0 'set pin 5 as input
lm34temp :=0 'starts the lm34temp variable as 0
temp:=ina 'sets the value of temp to the value of pin 5 (one or zero)
dira[noparse][[/noparse]7]~~ 'sets pin as output
outa[noparse][[/noparse]7]~~ 'sets pin 7 high
outa[noparse][[/noparse]7]~ 'sets pin 7 low 'takes chip select low activating the adc 'the ADC0831
repeat 8
dira[noparse][[/noparse]6]~~ 'sets pin as output
outa[noparse][[/noparse]6]:=1 'sets clock (pin 6) high
outa[noparse][[/noparse]6]:=0 'sets clock (pin 6)low 'takes the adc clk low
if ina==1
temp:=1
else
temp:=0
lm34temp:=lm34temp*2
lm34temp:=lm34temp+temp
waitcnt (1_000_000 * 50 + cnt )
LCD.init 'Initialize the display
LCD.writestr(@LineIt1) 'Display
repeat 'Just sit and run
dat
LineIt1 byte "Holder = ",lm34temp,$DF," C",cr,eos <----------------------------Here Lm34temp ? ? ?
Help please
What do you want to tell him??
when you say BYTE in DAT please only add constant byte values as 0, 255, -1, "A" or "ABC", the last is a simplification for "A", "B", "C".
You can also use CONS names of course, but not "lm34temp". That is not a constant!
LCD.writestr(@LineIt1) showDecimal(lm34temp) LCD.writestr(@LineIt2) PRI showDecimal(v) | p, t ' Display up to 3 digits, do zero supression t := 0 ' This is used as a string. Leave a zero byte for a terminator p := @t+3 ' Point to the zero terminator and work backwards repeat byte[noparse][[/noparse] --p ] := v // 10 + "0" ' Generate the digits from right to left v /= 10 ' Go to the next digit to the left until v == 0 ' Stop when there are no more digits to display LCD.writestr(p) DAT LineIt1 byte "Holder = ",0 LineIt2 byte $DF," C",cr,0
