String problem or data type problem ?
I need to know what data type this needs to be to correctly display. I am basicaly taking a temp reading and displaying it on my 2x20 lcd screen. The last line of code is were i get the compile error....
I get a compile error because i am not addressing the data type or something?
Help please
{{ Demo LCD Uses LCDDEMO Version 1.2 Uses ADC0831 with Lm34 as a temp }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 esc = $1B 'Escape code cr = $0D 'Carriage Return code lf = $0A 'Line Feed code eos = $FF 'End of string code eog = $FF 'End of graphics code space = $20 'Space character code var byte lm34temp, temp OBJ LCD : "LCDDEMO" pub main repeat dira :=0 'set pin 5 as input lm34temp :=0 'starts the lm34temp variable as 0 temp:=ina 'sets the value of temp to the value of pin 5 (one or zero) dira[noparse][[/noparse]7]~~ 'sets pin as output outa[noparse][[/noparse]7]~~ 'sets pin 7 high outa[noparse][[/noparse]7]~ 'sets pin 7 low 'takes chip select low activating the adc 'the ADC0831 repeat 8 dira[noparse][[/noparse]6]~~ 'sets pin as output outa[noparse][[/noparse]6]:=1 'sets clock (pin 6) high outa[noparse][[/noparse]6]:=0 'sets clock (pin 6)low 'takes the adc clk low if ina==1 temp:=1 else temp:=0 lm34temp:=lm34temp*2 lm34temp:=lm34temp+temp waitcnt (1_000_000 * 50 + cnt ) LCD.init 'Initialize the display LCD.writestr(@LineIt1) 'Display repeat 'Just sit and run dat LineIt1 byte "Holder = ",lm34temp,$DF," C",cr,eos <----------------------------Here Lm34temp ? ? ?
Help please
What do you want to tell him??
when you say BYTE in DAT please only add constant byte values as 0, 255, -1, "A" or "ABC", the last is a simplification for "A", "B", "C".
You can also use CONS names of course, but not "lm34temp". That is not a constant!
