Have Thing working
                    This is not a robot...· this is a computer on wheels.· It runs WiFi and and move about freely.· I do not want to call it a robot because it is not anonomous.· When the thing runs into to walls it needs to be reset.· I do not want to push the button or have to it reset or I do not want to IPL the computer OS.· The OS is XPE or XP Pro.· The Thing has two CAMS one is infra and the other is plan.· It is interesting what you can purchase for less than 20$.· I want to add stability and a way to reset all devices if there is a problem.· I do not want to IPL on the run because when it is in the yard I can get in the street.· Any ideas.
I want to turn the idea of the thing into something to clean my neighorhood.· It runs B or G WiFi.·
Any ideas...
Also I would like to build more intelligence into the Thing.· I know when it gets lost.· Does anyone have ideas for hooking PING off of USB direct?
Adam
Any ideas...
Adam
You could even buy and mount the PING servo bracket and have the Stamp build a map of the area and send that to the PC.
Can I hook other sensors off of the same stamp board. Can I hook 5 DC sensing devices off the same stamp board or will I need a stamp board for each application?
- Stephen
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
adam
