Encoder for Track Bot
Hi all,
I need some advice for parts and how to implement/fix encoder for my Track Bot.
http://forums.parallax.com/showthread.php?p=671001
Anybody have done this before?
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
I'm aware about the digital encoder for the boe bot but how·can i adapt it to my track bot.
Is there any other method?
Dgswaner,
I can't get any motor with build in encoder in my place.
EPIC FAILURE -·When everyday run-of-the-mill failure just isn't good enough.
Are u using Parallax digital encoder?
Can you please post some picture of your track vehicle so ican see clearly how you did it.
Thanks.
