Glueing expanded PVC
I'm using expanded PVC for the first time, what is the best glue to use? can I use PVC pipe glue?
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
There's nothing like a new idea and a warm soldering iron.
I've got to say expanded PVC it great stuff! I put together a Pan and tilt frame for some servos in about an hour. with only a miter saw and a drill! I'm hooked!
This is the same way that glue for plastic model kits works. The only problem I can think of might be that the solvent type glue might be too strong for the (less dense) expanded PVC and melt it completely away.
- Rick
The manufacturer says that won't melt away when using solvent but I personally feel that the nomal ketone based·liquid swabby stuff generally used for PVC pipes is very nasty (fumes, flammable, etc) which is why I mentioned GORILLA PVC. Designed for PVC pipes , but not a messy volatile liquid. Cleans up with water.
Post Edited (pwillard) : 10/19/2007 12:57:40 AM GMT
- Stephen
