Glueing expanded PVC — Parallax Forums
DgswanerDgswaner Posts: 795
edited 2007-10-19 01:05 in General Discussion
I'm using expanded PVC for the first time, what is the best glue to use? can I use PVC pipe glue?
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
  • pwillardpwillard Posts: 321
    edited 2007-10-17 20:10
    This stuff is tolerant of solvent glues and non-solvent polyurethane glue. You might try Gorilla-PVC glue.
    There's nothing like a new idea and a warm soldering iron.
  • DgswanerDgswaner Posts: 795
    edited 2007-10-17 20:27
    is that the same as the darker colored Gorilla glue? I haven't looked at the gorilla glue at home depot to see if it says PVC.
    edited 2007-10-18 01:45
    I'm not exactly sure what to say the color is... but it says Gorilla PVC right on the label.
    edited 2007-10-18 05:04
    I looked for gorilla glue for PVC but I couldn't find any, I bought Amazing GOOP. it said it was for PVC but I wouldn't call it amazing. I'm not sure if I gave it enough time to dry.. about 10 minutes, but I diced not to wait for it and screwed the expanded PVC together with screws.
    I've got to say expanded PVC it great stuff! I put together a Pan and tilt frame for some servos in about an hour. with only a miter saw and a drill! I'm hooked!
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-10-18 10:36
    PVC is a thermoplastic resin which is soluble in solvents such as ketones and esters. So-called glues made for PVC plumbing are mostly blends of these types of solvents, so what is happening when you use them is more like a weld than a glue joint. Each piece is partially dissolved by the "glue" then they fuse together at the joint. When the solvent in the glue evaporates, what you end up with is a more or less continuous piece of plastic.
    This is the same way that glue for plastic model kits works. The only problem I can think of might be that the solvent type glue might be too strong for the (less dense) expanded PVC and melt it completely away.
    - Rick
    edited 2007-10-19 00:52
    Supposedly, it's tolerant of the solvent based liquid bonding designed for pipes.
    The manufacturer says that won't melt away when using solvent but I personally feel that the nomal ketone based·liquid swabby stuff generally used for PVC pipes is very nasty (fumes, flammable, etc) which is why I mentioned GORILLA PVC. Designed for PVC pipes , but not a messy volatile liquid. Cleans up with water.
    Post Edited (pwillard) : 10/19/2007 12:57:40 AM GMT
    The sites I went to that make/sell the stuff seem to say the PVC pipe glue will work.
    - Stephen
