Pink Using an Image as an input button.
Yes, I've tried html forums, they are no where near as helpful as this site.
I swear I had this problem solved, so I made a graphical interface for web controlling a bot but now that I'm trying to get the pages to work on the pink it doesn't seem to work.
Here is a sample page. so you can see the problem. 71.219.98.215/controltest.htm
The regular submit buttons work fine, but when I try to use an image, It's returning the X value of the position on the image that was clicked. you can see what I mean by clicking on the left side of the Image vs the right side. I thought it was random at first, but it's not random.
I've done a lot of reading and I guess this is typical to return the x and y value of the click, but it's also supposed to return the value of the Value=" " statement. at least with Foxfire. IE doesn't support this.
Is there something I'm missing? This should work from what I have read.
I could use this as is but I would have to do a big huge work around and use a variable for each direction. I really would like a solution not a work around. and comments are welcome.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
I think what I'll do is just use it as is and then on the Processor side I'd watch for a value change, when it happens I'll set the value back to 0 and start watching again.
here is what I found about the image tag.
IMAGE: Create a graphical submit button rendered by an image rather than a text string. The x and y values of the location clicked are passed to the server: In the submitted data, image fields are included as two name/value pairs. The names are derived by taking the name of the field and appending ".x" for the x value, and ".y" for the y value.
www.webmaster.crevier.org/tags/TAG_INPUT.html
anyone else have any other ideas?
Basically, what you want to do is use a link onclick event and then submit the form manually. This is a bit complicated, but it will give cross browser compatibility.
- Stephen
If your ever passing though Utah let me know I owe you a steak dinner! let me know if there is anything I can help you with.
The following example uses document.forms[noparse][[/noparse]0].elements[noparse][[/noparse]0] to access the hidden field. This should allow ultimate browser compatability, but it does mean you cannot have any other form fields on the page.
<html> <head> <title>Control Test</title> <script language="javascript"> function sform(dir) { document.forms[noparse][[/noparse]0].elements[noparse][[/noparse]0].value = dir; document.forms[noparse][[/noparse]0].submit(); return false; } </script> </head> <body> Last Command: <Nb_var01><br /><br /> <form name="frm" id="frm" action="controltest.php" method="post"> <input type="hidden" name="Nb_var01" id="Nb_var01" value=""> </form> <a href="#" onClick="return sform('forward');"><img src="forward.png"></a> <a href="#" onClick="return sform('reverse');"><img src="reverse.png"></a> <a href="#" onClick="return sform('left');"><img src="left.png"></a> <a href="#" onClick="return sform('right');"><img src="right.png"></a> </body> </html>
For multiple forms and fields, use the following script section. This should work in all modern browsers, but I am not sure if it'll work on things like old PDAs and such.
<script language="javascript"> function sform(dir) { document.frm.Nb_var01.value = dir; document.frm.submit(); return false; } </script>
EDIT: typo
Harrison
Post Edited (Harrison.) : 10/15/2007 6:23:28 AM GMT
<div id="Button" style="position:absolute; z-index:10; visibility:visible; left:0px;top: 20px;"> <!-- MUST leave the LF in the following line --> <INPUT name="Nb_var10" type="hidden" value="0 "><INPUT type="image" src="image/button.GIF" border="0"></div>
Each 'button' has its own x-y value defined in LEFT: and TOP: and each button has a different 'name'. Note that you have to leave the Linefeed in the INPUT value. This puts·the required·terminating LF in the Nb_var.
Don't know if·you could put in the same name with different values for each button. I would think it would work.
Paul
are either of you familiar with Ajax, that's the only thing I will have left as far as the web interface. it will work with out AJAX but that will just add icing to the cake!
