Pink Using an Image as an input button. — Parallax Forums
DgswanerDgswaner Posts: 795
edited 2007-10-16 01:11 in General Discussion
Yes, I've tried html forums, they are no where near as helpful as this site.
I swear I had this problem solved, so I made a graphical interface for web controlling a bot but now that I'm trying to get the pages to work on the pink it doesn't seem to work.
Here is a sample page. so you can see the problem. 71.219.98.215/controltest.htm
The regular submit buttons work fine, but when I try to use an image, It's returning the X value of the position on the image that was clicked. you can see what I mean by clicking on the left side of the Image vs the right side. I thought it was random at first, but it's not random.
I've done a lot of reading and I guess this is typical to return the x and y value of the click, but it's also supposed to return the value of the Value=" " statement. at least with Foxfire. IE doesn't support this.
Is there something I'm missing? This should work from what I have read.
I could use this as is but I would have to do a big huge work around and use a variable for each direction. I really would like a solution not a work around. and comments are welcome.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
    edited 2007-10-10 23:28
    looking at the source shouldnt the line for the arrow have an input name= statement like the other lines do?
  • DgswanerDgswaner Posts: 795
    edited 2007-10-11 05:30
    the name= tag was there it was just at the end. I put it in the same order but still no go. I'm starting to think it's not possible, at least as a string. I will have to use the X coordinate value to determine if the button is pressed,
    I think what I'll do is just use it as is and then on the Processor side I'd watch for a value change, when it happens I'll set the value back to 0 and start watching again.
    here is what I found about the image tag.
    IMAGE: Create a graphical submit button rendered by an image rather than a text string. The x and y values of the location clicked are passed to the server: In the submitted data, image fields are included as two name/value pairs. The names are derived by taking the name of the field and appending ".x" for the x value, and ".y" for the y value.
    www.webmaster.crevier.org/tags/TAG_INPUT.html
    anyone else have any other ideas?
  • Harrison.Harrison. Posts: 484
    edited 2007-10-11 09:03
    This can all be done in javascript. I don't have time right now, but I could whip up an example this weekend.
    Basically, what you want to do is use a link onclick event and then submit the form manually. This is a bit complicated, but it will give cross browser compatibility.
    edited 2007-10-11 15:57
    Where is the submit for the arrow?
    - Stephen
    edited 2007-10-11 19:13
    Submit is what gives you the ugly gray button, you have to change type="submit" to "image" to get the image to show at all. from what I can tell the code is actually working the way it is supposed to. but it's not how I want it to work. I also don't think it's possible to get the Y value using this command.
    edited 2007-10-12 20:48
    Harrison, I'd love a sample script, I'm much better at modifying code as apposed to coming up with something new.
    If your ever passing though Utah let me know I owe you a steak dinner! let me know if there is anything I can help you with.
    edited 2007-10-15 06:16
    Here's the example I promised. Sorry about how long it took. I was lazy and totally forgot about this.
    The following example uses document.forms[noparse][[/noparse]0].elements[noparse][[/noparse]0] to access the hidden field. This should allow ultimate browser compatability, but it does mean you cannot have any other form fields on the page.
    <html>
    <head>
    <title>Control Test</title>
    <script language="javascript">
    function sform(dir) {
        document.forms[noparse][[/noparse]0].elements[noparse][[/noparse]0].value = dir;
        document.forms[noparse][[/noparse]0].submit();
        return false;
    </script>
    </head>
    <body>
    Last Command: <Nb_var01><br /><br />
    <form name="frm" id="frm" action="controltest.php" method="post">
    <input type="hidden" name="Nb_var01" id="Nb_var01" value="">
    </form>
    <a href="#" onClick="return sform('forward');"><img src="forward.png"></a>
    <a href="#" onClick="return sform('reverse');"><img src="reverse.png"></a>
    <a href="#" onClick="return sform('left');"><img src="left.png"></a>
    <a href="#" onClick="return sform('right');"><img src="right.png"></a>
    </body>
    </html>
    For multiple forms and fields, use the following script section. This should work in all modern browsers, but I am not sure if it'll work on things like old PDAs and such.
        document.frm.Nb_var01.value = dir;
        document.frm.submit();
        return false;
    </script>
    EDIT: typo
    Harrison
    Post Edited (Harrison.) : 10/15/2007 6:23:28 AM GMT
  • PaulPaul Posts: 263
    edited 2007-10-15 13:03
    I've been using multiple virtual buttons in forms (in IE)·with this code:
        <div id="Button" style="position:absolute; z-index:10; visibility:visible; left:0px;top: 20px;">
            <!-- MUST leave the LF in the following line -->
          <INPUT name="Nb_var10" type="hidden" value="0
    "><INPUT type="image" src="image/button.GIF" border="0"></div>
    Each 'button' has its own x-y value defined in LEFT: and TOP: and each button has a different 'name'. Note that you have to leave the Linefeed in the INPUT value. This puts·the required·terminating LF in the Nb_var.
    Don't know if·you could put in the same name with different values for each button. I would think it would work.
    Paul
    edited 2007-10-15 14:31
    Harrison your definitely on my Christmas list! it Works Great! thanks for your time, one thing, you code says: action="controltest.php" I didn't know if I was supposed to name my file .php, the code didn't work at first because I had .htm so I changed the code to controltest.htm and it works. Thanks for your time on this, I'm getting really close to completing my web enabled bot.
    edited 2007-10-15 21:51
    Paul, I can't get your code to work, I'll dig into it a little deeper when I get home, are you saying that it returns the x and y values, or is that just the position in the page? from what I can tell it's the latter.
    are either of you familiar with Ajax, that's the only thing I will have left as far as the web interface. it will work with out AJAX but that will just add icing to the cake!
    Ajax is actually quite easy to do when you use a premade framework. What I recommend is taking a look at mootools (mootools.net/). Mootools gives you very streamlined access to page elements while also incorporating a nice ajax api.
