Video Stream on the web. [working thanks for the help]
I'm using a logitech quick cam for and a program called Vision GS www.visiongs.de/ it's a very useful program and it's worked well for many other applications, but when i'm streaming Video over the web, it generates code that embeds windows media player, everything works but it buffers for 5 seconds, if I'm viewing a bot for web control I can't be that far behind. I've tried to have it not buffer but for some reason no matter what I set it to it buffers for 5 seconds. I think the issue lies with windows media player.
Question: does anyone know a video streaming program/method that will give very close to real time streaming? I will eventually be buying a wireless camera that will be on the bot so a wireless camera/program package would be good also.
I know it's not just a lag issue it buffers for 5 seconds even on the same computer as the cam.
added
if you catch me picking my nose you get 5 points
see the link below
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Post Edited (Dgswaner) : 10/20/2007 3:12:19 PM GMT
added
see the link below
There's nothing like a new idea and a warm soldering iron.
It's Only A Stupid Question If You Have Not Googled It First!!
71.219.89.202/Cam_stills.html
Thanks If you could PM me with the results I would appreciate it.
you may have to press the "WAN" button.
Added: I think I got it this time! can some one try this and let me know if it works. Thanks
Post Edited (Dgswaner) : 10/20/2007 7:25:33 AM GMT
- Rick
Added: Steve, I'm most likely not going to have anything to show this weekend I think I fried the Max232 chip on my bot, it works I just can't communicate with it to reprogram it.... but I think I'll be done enough to post the Pink code and web pages.
Post Edited (Dgswaner) : 10/20/2007 3:23:56 PM GMT
can someone using Vista and IE try the streaming... i got a message about it not working. I'm streaming on port 85. I'm betting it's a firewall issue.
