Video Stream on the web. [working thanks for the help] — Parallax Forums
DgswanerDgswaner Posts: 795
edited 2007-10-20 15:52 in General Discussion
I'm using a logitech quick cam for and a program called Vision GS www.visiongs.de/ it's a very useful program and it's worked well for many other applications, but when i'm streaming Video over the web, it generates code that embeds windows media player, everything works but it buffers for 5 seconds, if I'm viewing a bot for web control I can't be that far behind. I've tried to have it not buffer but for some reason no matter what I set it to it buffers for 5 seconds. I think the issue lies with windows media player.
Question: does anyone know a video streaming program/method that will give very close to real time streaming? I will eventually be buying a wireless camera that will be on the bot so a wireless camera/program package would be good also.
I know it's not just a lag issue it buffers for 5 seconds even on the same computer as the cam.
added
if you catch me picking my nose you get 5 points
see the link below
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Post Edited (Dgswaner) : 10/20/2007 3:12:19 PM GMT
  • pwillardpwillard Posts: 321
    edited 2007-10-13 20:08
    Your in luck. We'll never catch you with that link. It's a private address used by your local network and not reachable from the Internet.
    There's nothing like a new idea and a warm soldering iron.
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2007-10-13 21:45
    try it this way http://71.219.98.215/stream.html
    It's Only A Stupid Question If You Have Not Googled It First!!
  • kelvin jameskelvin james Posts: 531
    edited 2007-10-13 21:59
    I had a look at the software site, in the initial setup it has a FTP upload time interval setting, like a delay adjustable in seconds. Just wondering if this could be the problem?
  • DgswanerDgswaner Posts: 795
    edited 2007-10-13 23:12
    oh your are right I have to keep changing th link to look at the cam from home, I posted the wrong IP. the FTP interval is for uploading still images to a host server not for streaming. but thanks for the effort I'll fix the IP
    edited 2007-10-20 03:00
    Would someone be so kind as to see if my video is working from outside my network? thanks
    71.219.89.202/Cam_stills.html
    Thanks If you could PM me with the results I would appreciate it.
    you may have to press the "WAN" button.
    Added: I think I got it this time! can some one try this and let me know if it works. Thanks
    Post Edited (Dgswaner) : 10/20/2007 7:25:33 AM GMT
  • RDL2004RDL2004 Posts: 2,554
    edited 2007-10-20 09:57
    It works, but only after using the WAN button. After that the picture showed up but the connection was constantly refreshing even though the picture didn't change.
    - Rick
  • Steve JoblinSteve Joblin Posts: 784
    edited 2007-10-20 14:39
    Dgswaner - have you looked at www.roborealm.com?
    edited 2007-10-20 15:18
    Steve, I have seen that but I totally forgot about it! I'm really going to have to get into it. especially since I have to use a PC to to stream the images anyway.
    Added: Steve, I'm most likely not going to have anything to show this weekend I think I fried the Max232 chip on my bot, it works I just can't communicate with it to reprogram it.... but I think I'll be done enough to post the Pink code and web pages.
    Post Edited (Dgswaner) : 10/20/2007 3:23:56 PM GMT
    edited 2007-10-20 15:39
    My sincerest condolences on the passing of your Max232... Can't wait to see your progress on this... it sounds really cool!
    lol ya I was bumbed.. as I was connecting the serial cable there was a big "ZAP" of static and I was like oh man!!!!! luckily the stamp still works.
    can someone using Vista and IE try the streaming... i got a message about it not working. I'm streaming on port 85. I'm betting it's a firewall issue.
