Using PAR for accessing more than one variable — Parallax Forums
HarleyHarley Posts: 997
edited 2007-10-08 00:14 in Propeller 1
So far only one variable has needed to be accessed by ASM from Spin..
I'm using PASD (really works great), I can see the variables I'm using, but the program doesn't 'see' them.
If I write
      mov   ptr,PAR                  ' I can see valid ptr value
      rdlong temp,ptr                ' gets the value
      rdlong temp2,(ptr + 4)     ' doesn't get the next value at ptr + 4; WHY?
' and so on
Is there a better way to do this? If so, what is it called? I couldn't find anything wrong with what I'd planned to use in Prop manual, deSilva's writings, or even using the 'Google search' Seems some details have been skipped for beginning into this area.
Harley Shanko
    edited 2007-10-07 21:17
    Try:
    mov ptr,PAR
    rdlong temp,ptr
    add ptr,#4
    rdlong temp2,ptr
    Basically you can't do "(ptr+4)" as ptr holds the address of a pointer, that needs to be incremented by a separate instruction.
    Hope this helps,
    Bill
    Harley said...
    If I write
    ' and so on
    www.mikronauts.com - a new blog about microcontrollers
  • deSilvadeSilva Posts: 2,967
    ptr +4 is the register 4 cells behind prt - You have to ADD 4 to ptr to do want you want...
  • HarleyHarley Posts: 997
    edited 2007-10-07 21:23
    Shucks,
    Anything to slow down ASM. Wish Chip had allowed an offset.
    Thanks guys.
    Harley Shanko
    edited 2007-10-07 21:25
    Post Edited (deSilva) : 10/7/2007 9:48:04 PM GMT
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-10-07 22:15
    Ah yes, ve like leather, vhips, and violins. Hairshirt, anyone?
    For sake of discussion, where would the offset go?
    Look at the instruction long bits. They are all essentially performing some purpose. More bits then are needed to fetch the offset, and isn't that just the same as fetching another instruction?
    Immediate operands, bigger than $1ff are the same way. No instruction bits, so it gets fetched from one of the other COG longs.
    Something would have to give, in order for these cases to be written as one instruction. (maybe somebody could entertain a macro assembler...) If instruction words vary, like the cases above, then COG addressing also must vary, or we end up with a lot more wasted bits being fetched to complete instructions that really are two instructions, in terms of operation performed. Thus overall instruction word length either grows, or we get fewer overall instructions. (A lot fewer, as it would take a lot of bits to really make an impact)
    The net result of all of that really is more words fetched to perform the same tasks --a net loss in speed, for all but a few cases.
