Propeller trouble
In Propeller Tool:
F7 - Identify Hardware - "Propeller chip version 1 found on COM 6."
F10 - Load RAM - "Propeller chip lost on COM 6."
Where's error? I can't upload programme to the chip.
Thanks, Lafet
Thanks, Lafet
have something connecting to pins 28-31. (These are used for I2C
EEPROM and serial download.) 2 - Make sure nothing is touching the
XTAL pins.
I was holding the Propeller demo board in my hand and must have been
making contact with the crystal in one case. In the other case I had
a buffer chip which was putting some minor loading on one or more
of pins 28-31.
Good Luck,
Bot-Man
F7 - Identify Hardware - OK
F10 - Load RAM - ? Error
Why on F7 chip responds and on F10 no? If be at fault crystal, so would not function F7.
EEPROM I haven't connected.
I found that happened to me if the prop terminal connected to the prop first (as yours does), but another program tried to write to COM6 soon after.
It interfered with the comms or something.
It found the prop ok and connected, but the lost the prop.
-Alec
My our page
This happens when programming the EEPROM if the EEPROM pins are shorted, perhaps if the prop's 2 i2c pins are shorted you get the same issue?
-Alec
My our page
I use a 220uF electrolytic, its more than enough. If you have an oscilloscope, monitor the 3.3v for noise. this is most likely if you are using a max3232 to convert RS232 voltage, as i recall, they create huge oscillations that are enough to completely disrupt the prop.
Holy parallel processing, Batman!
Post Edited (Mr Crowley) : 10/5/2007 12:30:33 AM GMT
F10 does not even touch the EEPROM lines
"Lost connection" generally indicates the Prop has reset inbetween.
Reasons for that can be:
- Problems with the "reset logic" of a customer circuit
- Power problems.
Though Parallax does not seem to strictly recommend this, it is very good practice for more than 30 years now to add a 100nF ceramic close to any chip... (Between plus and minus, before you ask..)
A large electrolyte will do no harm, but will not always help...
Circuit on solderless connecting boards
Between PC and Propeller is USB Prop Clip.
Worked it so already for a longer time, but from yesterday works wrong.
Lafet
Amusements aside, when I first ran a battery down to the point of Prop-Don't-Work-Anymore I realized that, as nifty as the PEKit was, if I didn't have a spare, the failure of just about any part would stop me in my tracks. So I bought another PEKit. And have about 4 spare batteries too.
