Propeller trouble — Parallax Forums
Propeller trouble
LafetLafet Posts: 23
edited 2007-10-05 19:21 in Propeller 1
In Propeller Tool:
F7 - Identify Hardware - "Propeller chip version 1 found on COM 6."
F10 - Load RAM - "Propeller chip lost on COM 6."
Where's error? I can't upload programme to the chip.
Thanks, Lafet
  • ClemensClemens Posts: 236
    edited 2007-10-04 21:11
    Are you running the propeller on battery? I had the message once when my battery was low.
  • bot-manbot-man Posts: 22
    edited 2007-10-04 21:13
    I ran into this last night. Two things to check, 1 - make sure you do not
    have something connecting to pins 28-31. (These are used for I2C
    EEPROM and serial download.) 2 - Make sure nothing is touching the
    XTAL pins.
    I was holding the Propeller demo board in my hand and must have been
    making contact with the crystal in one case. In the other case I had
    a buffer chip which was putting some minor loading on one or more
    of pins 28-31.
    Good Luck,
    Bot-Man
  • LafetLafet Posts: 23
    edited 2007-10-04 21:37
    But
    F7 - Identify Hardware - OK
    F10 - Load RAM - ? Error
    Why on F7 chip responds and on F10 no? If be at fault crystal, so would not function F7.
    EEPROM I haven't connected.
  • RaymanRayman Posts: 16,228
    edited 2007-10-04 22:07
    Are you using USB or regular serial connection?
  • BasilBasil Posts: 380
    edited 2007-10-05 00:00
    Hi Lafet,
    I found that happened to me if the prop terminal connected to the prop first (as yours does), but another program tried to write to COM6 soon after.
    It interfered with the comms or something.
    It found the prop ok and connected, but the lost the prop.
    -Alec
    My our page
    edited 2007-10-05 00:02
    Sorry forgot to ask, are you using your own board or one of parallax's?
    This happens when programming the EEPROM if the EEPROM pins are shorted, perhaps if the prop's 2 i2c pins are shorted you get the same issue?
    -Alec
    My our page
  • Lee MarshallLee Marshall Posts: 106
    edited 2007-10-05 00:21
    If you are using your own board(like me), make sure there is enough capacitance between the 3.3v and the 0v rail.
    I use a 220uF electrolytic, its more than enough. If you have an oscilloscope, monitor the 3.3v for noise. this is most likely if you are using a max3232 to convert RS232 voltage, as i recall, they create huge oscillations that are enough to completely disrupt the prop.
    Holy parallel processing, Batman!
    Post Edited (Mr Crowley) : 10/5/2007 12:30:33 AM GMT
  • deSilvadeSilva Posts: 2,967
    edited 2007-10-05 03:45
    F7 o.k. shows that ALL comm works (SND, RCV, RESET)
    F10 does not even touch the EEPROM lines
    "Lost connection" generally indicates the Prop has reset inbetween.
    Reasons for that can be:
    - Problems with the "reset logic" of a customer circuit
    - Power problems.
    Though Parallax does not seem to strictly recommend this, it is very good practice for more than 30 years now to add a 100nF ceramic close to any chip... (Between plus and minus, before you ask..)
    A large electrolyte will do no harm, but will not always help...
    edited 2007-10-05 07:05
    Thanks everyone,
    Circuit on solderless connecting boards
    Between PC and Propeller is USB Prop Clip.
    Worked it so already for a longer time, but from yesterday works wrong.
    Lafet
    edited 2007-10-05 17:44
    So exchange the chip, which is no task on the breadboard. And don't say you have no second Prop... The basic rule for any serious electronic hobbyist is to have EVERYTHING at leat twice smile.gif
  • Fred HawkinsFred Hawkins Posts: 997
    deSilva, you are starting to sound like my father after my seven-year-old self lost his shovel (which was bigger than me) -- "Show me a man with kids and I'll show you someone who has bought everything and has nothing".
    Amusements aside, when I first ran a battery down to the point of Prop-Don't-Work-Anymore I realized that, as nifty as the PEKit was, if I didn't have a spare, the failure of just about any part would stop me in my tracks. So I bought another PEKit. And have about 4 spare batteries too.
