Need help with a little optimization
I have been playing around with this code for a while, I'm slowly getting it down in size and I want to work on the Change Direction section of the Code.
Currently these pins control the motor directions of both M1 and M2 motors, One is high while the other is low.
M1_INA Pin RB.7 Output
M1_INB Pin RB.2 Output
M2_INA Pin RC.3 Output
M2_INB Pin RC.1 Output
Looking below does anyone have any suggestion on how to make this code more optimized?
Thanks in Advance,
Eric
Thanks in Advance,
Eric
DEVICE SX48, OSCHS3
FREQ 50_000_000
ID "MotorV.1"
Baud CON "T19210"
DataInPin Pin RB.0 Input
DataOutPin Pin RB.1 OutPut
MOTOR Var Byte
Direction Var Byte(2)
Speed Var Byte(2)
MarkSpeed Var Byte
Delay Var Byte
Index Var Byte
tmpB1 Var byte
tmpB2 Var Byte
Temp Var byte
MOTOR Var Byte
Command Var byte
LED0 Pin RD.0
LED1 Pin RD.1
LED2 Pin RD.2
LED3 Pin RD.3
LED4 Pin RE.0
LED5 Pin RE.1
LED6 Pin RE.2
LED7 Pin RE.3
M1_PWM Pin RB.6 Output
M2_PWM Pin RC.2 Output
INTERRUPT 1000
TIMER1 PWM,Speed(1),256
TIMER2 PWM,Speed(2),256
RETURNINT
ACK Sub 0
SendData Sub 1
SET_SPEED Sub 0
Change_Direction Sub 0
Get_Info Sub 0
GetData Func 1
RB=%0100_0000
RC=%0000_1000
PROGRAM Start NoStartup
Start:
Tris_C=%00000000
Tris_E=%00000000
Tris_D=%00000000
Tris_B=%00000000
Main:
Do
DO
Command=GetData
LOOP UNTIL Command = "!"
DO
Command=GetData
LOOP UNTIL Command = "M"
DO
Command=GetData
LOOP UNTIL Command = "C"
Command=GetData
ON Command = "S", "D", "I" GOSUB SET_SPEED , Change_Direction, Get_Info
Loop
SET_SPEED:
High LED0
MOTOR=GetData
Speed(MOTOR)=GetData
ACK
Speed(MOTOR)=Speed(MOTOR) Max 128
Low LED0
Return
Change_Direction:
MOTOR=GetData
Temp=GetData
ACK
High LED1
If Direction(MOTOR)= Temp Then E_X_I_T
MarkSpeed=Speed(MOTOR)
Do
DEC Speed(MOTOR)
Speed(MOTOR) = Speed(MOTOR) Min 1
Pause 5
LOOP Until Speed(MOTOR)=1
If MOTOR=1 Then
If Direction(1)=1 Then
High M1_INA
Low M1_INB
ElseIf Direction(1)=2 Then
High M1_INB
Low M1_INA
EndIF
EndIf
If MOTOR=2 Then
If Direction(2)=1 Then
High M2_INA
Low M2_INB
ElseIf Direction(2)=2 Then
High M2_INB
Low M2_INA
EndIF
EndIf
Do
Inc Speed(MOTOR)
Speed(MOTOR) = Speed(MOTOR) Max MarkSpeed
Pause 5
LOOP Until Speed(MOTOR)=MarkSpeed
Low LED1
E_X_I_T:
Return
Get_Info:
Return
Fault:
HIGH LED3
PAUSE 10
LOW LED3
Return
ACK:
SendData "A"
SendData "C"
SendData "K"
Return
Return
SendData:
SerOut DataOutPin,Baud,__Param1
Return
GetData:
SerIn DataInPin,Baud,__Param1,100,FAULT
Return __Param1
If you wish to reduce codespace you can remove a few of your IF and ELSE statements while still maintaining nearly the same functionality. For example, you check to see if you are addressing motor #1 and if so you handle changes to its data. Next you check to see if you are addressing motor #2 and if you are you handle changes to its data. I do not think you expect to change both motors during the same pass through the subroutine. You could therefore assume that if you are not processing data for motor #1 then you must be processing data for Motor #2. You could handle direction changes in a similar fashion. This will result in a codespace reduction. The drawback is that you must insure elsewhere (wherever these commands are being generated) that the assumptions being made will always be true! The subroutine as you have it written now will ignore commands for motor numbers larger than two. If you reduce some of the logic statements to save some space, any motor number greater than one will be treated as though it ought to be addressing motor two. If it is unlikely that invalid commands will be sent then you can save a few bytes of codespace by assuming that if condition one is not met than condition two probably was.
I realize this may not be the type of “optimization” you desired; but it is what came to my mind!
- Sparks
Eric
