Need help with a little optimization — Parallax Forums
SailerManSailerMan Posts: 337
edited 2007-10-04 01:57 in General Discussion
I have been playing around with this code for a while, I'm slowly getting it down in size and I want to work on the Change Direction section of the Code.
Currently these pins control the motor directions of both M1 and M2 motors, One is high while the other is low.
M1_INA Pin RB.7 Output
M1_INB Pin RB.2 Output
M2_INA Pin RC.3 Output
M2_INB Pin RC.1 Output
Looking below does anyone have any suggestion on how to make this code more optimized?
Thanks in Advance,
Eric
DEVICE          SX48, OSCHS3
FREQ            50_000_000
ID  "MotorV.1"
Baud        CON    "T19210"
DataInPin             Pin     RB.0 Input
DataOutPin            Pin     RB.1 OutPut
MOTOR                    Var     Byte
Direction            Var     Byte(2)
Speed                Var    Byte(2)
MarkSpeed            Var    Byte
Delay                  Var     Byte
Index                    Var        Byte
tmpB1                   Var     byte
tmpB2                   Var     Byte
Temp                Var     byte
MOTOR                    Var     Byte
Command             Var    byte
LED0    Pin RD.0
LED1    Pin RD.1
LED2    Pin RD.2
LED3    Pin RD.3
LED4    Pin RE.0
LED5    Pin RE.1
LED6    Pin RE.2
LED7    Pin RE.3
M1_PWM    Pin RB.6 Output
M2_PWM    Pin RC.2 Output
INTERRUPT 1000
    TIMER1 PWM,Speed(1),256
    TIMER2 PWM,Speed(2),256
RETURNINT
ACK                Sub 0
SendData             Sub 1
SET_SPEED             Sub 0
Change_Direction         Sub 0
Get_Info             Sub 0
GetData             Func 1
RB=%0100_0000
RC=%0000_1000
PROGRAM Start NoStartup
Start:
Tris_C=%00000000
Tris_E=%00000000
Tris_D=%00000000
Tris_B=%00000000
Main:
Do
         DO
              Command=GetData
        LOOP UNTIL Command = "!"
           DO
              Command=GetData
        LOOP UNTIL Command = "M"
        DO
              Command=GetData
        LOOP UNTIL Command = "C"
        Command=GetData
        ON Command = "S", "D", "I" GOSUB  SET_SPEED , Change_Direction, Get_Info
Loop
SET_SPEED:
            High LED0
            MOTOR=GetData
            Speed(MOTOR)=GetData
            ACK
            Speed(MOTOR)=Speed(MOTOR) Max 128
            Low LED0
Return
Change_Direction:
            MOTOR=GetData
            Temp=GetData
            ACK
            High LED1
            If Direction(MOTOR)= Temp Then E_X_I_T
            MarkSpeed=Speed(MOTOR)
            Do
                DEC Speed(MOTOR)
                Speed(MOTOR) = Speed(MOTOR) Min 1
                Pause 5
            LOOP Until Speed(MOTOR)=1
            If MOTOR=1 Then
                If Direction(1)=1 Then
                    High M1_INA
                    Low M1_INB
                ElseIf Direction(1)=2 Then
                    High M1_INB
                    Low M1_INA
                EndIF
            EndIf
             If MOTOR=2 Then
                If Direction(2)=1 Then
                    High M2_INA
                    Low M2_INB
                ElseIf Direction(2)=2 Then
                    High M2_INB
                    Low M2_INA
                EndIF
            EndIf
            Do
                Inc Speed(MOTOR)
                Speed(MOTOR) = Speed(MOTOR) Max MarkSpeed
                Pause 5
            LOOP Until Speed(MOTOR)=MarkSpeed
            Low LED1
E_X_I_T:
Return
Get_Info:
Return
Fault:
    HIGH LED3
    PAUSE 10
    LOW LED3
Return
ACK:
    SendData "A"
    SendData "C"
    SendData "K"
Return
Return
SendData:
    SerOut DataOutPin,Baud,__Param1
Return
GetData:
    SerIn  DataInPin,Baud,__Param1,100,FAULT
Return __Param1
  • Sparks-R-FunSparks-R-Fun Posts: 388
    edited 2007-10-03 18:11
    Eric,
    If you wish to reduce codespace you can remove a few of your IF and ELSE statements while still maintaining nearly the same functionality. For example, you check to see if you are addressing motor #1 and if so you handle changes to its data. Next you check to see if you are addressing motor #2 and if you are you handle changes to its data. I do not think you expect to change both motors during the same pass through the subroutine. You could therefore assume that if you are not processing data for motor #1 then you must be processing data for Motor #2. You could handle direction changes in a similar fashion. This will result in a codespace reduction. The drawback is that you must insure elsewhere (wherever these commands are being generated) that the assumptions being made will always be true! The subroutine as you have it written now will ignore commands for motor numbers larger than two. If you reduce some of the logic statements to save some space, any motor number greater than one will be treated as though it ought to be addressing motor two. If it is unlikely that invalid commands will be sent then you can save a few bytes of codespace by assuming that if condition one is not met than condition two probably was.
    I realize this may not be the type of “optimization” you desired; but it is what came to my mind!
    - Sparks
  • SailerManSailerMan Posts: 337
    Thanks for the reply... I was thinking that I could change which pins I'm using and Use some kind of magic boolean math to make it shorter. You Idea it a great one and I will use it. Thanks.
    Eric
