Create a Super Spy Clock with BASIC Stamp (beginner kit) — Parallax Forums
cavnebcavneb Posts: 1
edited 2007-09-17 15:34 in BASIC Stamp
I was looking for a simple, yet fun thing I could create with my beginner set. I saw the cricket prank and loved it, but there were not many others I could find. I decided to try to create a clock using only the parts that were provided in the BASIC Stamp (w/ Homework Board) kit. Due to the limited amount of 7-segment LCD displays, I had to get creative on keeping the time. What came of this is the Super Spy Clock!
Here is the code for it:
' {$STAMP BS2}
' {$PBASIC 2.5}
' This is my first non-book project with the BASIC Stamp Homeword Board and initial kit.
' I was looking at some watches on Amazon.com and found that their Tokyo brand watches were
' all cryptic and cool.  I wanted to see if I could make one with my new BASIC Stamp kit.
' Here is what I came up with.
' Define Variables
initial_hour    VAR   Byte
initial_five    VAR   Byte
initial_min     VAR   Byte
counter         VAR   Byte
five_minutes    VAR   Byte
minute_counter  VAR   Byte
hour_marker     VAR   Byte
hours           VAR   Byte
' Initialize the 7-Segment LED Display
OUTH = %00000000
DIRH = %11111111
' Set Initial Values for variables
hours = 1
five_minutes = 0
minute_counter = 0
hour_marker = 0
' Main Loop
DO
  FOR counter = 0 TO 59
    IF (IN0 = 1) THEN
      GOSUB ADD_MINUTE
    ENDIF
    GOSUB DISPLAY_TIME
    HIGH 11
    PAUSE 10
    LOW 11
    PAUSE 990
  NEXT
  GOSUB ADD_MINUTE
LOOP
' Add a minute to the time
ADD_MINUTE:
  IF minute_counter <> 4 THEN
    minute_counter = minute_counter + 1
  ELSE
    minute_counter = 0
    IF five_minutes <> 11 THEN
      five_minutes = five_minutes + 1
    ELSE
      five_minutes = 0
      IF hours <> 6 THEN
        hours = hours + 1
      ELSE
        hours = 1
        IF hour_marker = 0 THEN
          hour_marker = 1
        ELSE
          hour_marker = 0
        ENDIF
        GOSUB TOGGLE_SIX_HOUR_LED
      ENDIF
    ENDIF
  ENDIF
  RETURN
' Display the minute LEDs and the 7-Segment Display
DISPLAY_TIME:
  GOSUB DISPLAY_MINUTES
  GOSUB DISPLAY_HOURS_AND_FIVES
  RETURN
' This is the part of my code that I am not too happy with.  I tried to create a hash of
' minutes and hours with their respective codes, but I couldn't figure out how to convert
' multiple values into a binary string that OUTH accepts.  Here's my version (the long one)
DISPLAY_HOURS_AND_FIVES:
  SELECT hours
    CASE 1
      SELECT five_minutes
        CASE 0
          OUTH = %00000001
          RETURN
        CASE 1
          OUTH = %00100001
          RETURN
        CASE 2
          OUTH = %01000001
          RETURN
        CASE 3
          OUTH = %10000001
          RETURN
        CASE 4
          OUTH = %00010001
          RETURN
        CASE 5
          OUTH = %01100001
          RETURN
        CASE 6
          OUTH = %11000001
          RETURN
        CASE 7
          OUTH = %10010001
          RETURN
        CASE 8
          OUTH = %00110001
          RETURN
        CASE 9
          OUTH = %11100001
          RETURN
        CASE 10
          OUTH = %11010001
          RETURN
        CASE 11
          OUTH = %10110001
          RETURN
        CASE ELSE
          DEBUG "ERROR"
          RETURN
      ENDSELECT
    CASE 2
      SELECT five_minutes
        CASE 0
          OUTH = %00000010
          RETURN
        CASE 1
          OUTH = %00100010
          RETURN
        CASE 2
          OUTH = %01000010
          RETURN
        CASE 3
          OUTH = %10000010
          RETURN
        CASE 4
          OUTH = %00010010
          RETURN
        CASE 5
          OUTH = %01100010
          RETURN
        CASE 6
          OUTH = %11000010
          RETURN
        CASE 7
          OUTH = %10010010
          RETURN
        CASE 8
          OUTH = %00110010
          RETURN
        CASE 9
          OUTH = %11100010
          RETURN
        CASE 10
          OUTH = %11010010
          RETURN
        CASE 11
          OUTH = %10110010
          RETURN
        CASE ELSE
          RETURN
      ENDSELECT
    CASE 3
      SELECT five_minutes
       CASE 0
          OUTH = %00000100
          RETURN
        CASE 1
          OUTH = %00100100
          RETURN
        CASE 2
          OUTH = %01000100
          RETURN
        CASE 3
          OUTH = %10000100
          RETURN
        CASE 4
          OUTH = %00010100
          RETURN
        CASE 5
          OUTH = %01100100
          RETURN
        CASE 6
          OUTH = %11000100
          RETURN
        CASE 7
          OUTH = %10010100
          RETURN
        CASE 8
          OUTH = %00110100
          RETURN
        CASE 9
          OUTH = %11100100
          RETURN
        CASE 10
          OUTH = %11010100
          RETURN
        CASE 11
          OUTH = %10110100
          RETURN
        CASE ELSE
          RETURN
      ENDSELECT
    CASE 4
      SELECT five_minutes
       CASE 0
          OUTH = %00000011
          RETURN
        CASE 1
          OUTH = %00100011
          RETURN
        CASE 2
          OUTH = %01000011
          RETURN
        CASE 3
          OUTH = %10000011
          RETURN
        CASE 4
          OUTH = %00010011
          RETURN
        CASE 5
          OUTH = %01100011
          RETURN
        CASE 6
          OUTH = %11000011
          RETURN
        CASE 7
          OUTH = %10010011
          RETURN
        CASE 8
          OUTH = %00110011
          RETURN
        CASE 9
          OUTH = %11100011
          RETURN
        CASE 10
          OUTH = %11010011
          RETURN
        CASE 11
          OUTH = %10110011
          RETURN
        CASE ELSE
          RETURN
      ENDSELECT
    CASE 5
      SELECT five_minutes
        CASE 0
          OUTH = %00000110
          RETURN
        CASE 1
          OUTH = %00100110
          RETURN
        CASE 2
          OUTH = %01000110
          RETURN
        CASE 3
          OUTH = %10000110
          RETURN
        CASE 4
          OUTH = %00010110
          RETURN
        CASE 5
          OUTH = %01100110
          RETURN
        CASE 6
          OUTH = %11000110
          RETURN
        CASE 7
          OUTH = %10010110
          RETURN
        CASE 8
          OUTH = %00110110
          RETURN
        CASE 9
          OUTH = %11100110
          RETURN
        CASE 10
          OUTH = %11010110
          RETURN
        CASE 11
          OUTH = %10110110
          RETURN
        CASE ELSE
          RETURN
      ENDSELECT
    CASE 6
      SELECT five_minutes
       CASE 0
          OUTH = %00000111
          RETURN
        CASE 1
          OUTH = %00100111
          RETURN
        CASE 2
          OUTH = %01000111
          RETURN
        CASE 3
          OUTH = %10000111
          RETURN
        CASE 4
          OUTH = %00010111
          RETURN
        CASE 5
          OUTH = %01100111
          RETURN
        CASE 6
          OUTH = %11000111
          RETURN
        CASE 7
          OUTH = %10010111
          RETURN
        CASE 8
          OUTH = %00110111
          RETURN
        CASE 9
          OUTH = %11100111
          RETURN
        CASE 10
          OUTH = %11010111
          RETURN
        CASE 11
          OUTH = %10110111
          RETURN
        CASE ELSE
          RETURN
      ENDSELECT
    CASE ELSE
  ENDSELECT
' Displays Minute LEDs
DISPLAY_MINUTES:
  GOSUB CLEAR_MINUTES
  SELECT minute_counter
    CASE 1
      HIGH 2
      RETURN
    CASE 2
      HIGH 3
      RETURN
    CASE 3
      HIGH 2
      HIGH 4
      RETURN
    CASE 4
      HIGH 3
      HIGH 4
      RETURN
    CASE ELSE
  ENDSELECT
  RETURN
' Clears out the minute LEDs
CLEAR_MINUTES:
  LOW 2
  LOW 3
  LOW 4
  RETURN
' This shows whether the hour clock is 1-6 or 7-12.
TOGGLE_SIX_HOUR_LED:
  IF hour_marker = 1 THEN
    HIGH 5
  ELSE
    LOW 5
  ENDIF
  RETURN
Post Edited (cavneb) : 9/16/2007 9:48:10 PM GMT
    edited 2007-09-17 00:23
    How long does it take you to "read" that?
    [noparse][[/noparse] "What time is it, cavneb?" ]
    You could conserve a lot of program space by putting the patterns into DATA statements just once and calling the pattern based on the index. That way you don’t need all those CASE statements and repeating all the patterns. Take care.
    Chris Savage
    Parallax Tech Support
