Create a Super Spy Clock with BASIC Stamp (beginner kit)
I was looking for a simple, yet fun thing I could create with my beginner set. I saw the cricket prank and loved it, but there were not many others I could find. I decided to try to create a clock using only the parts that were provided in the BASIC Stamp (w/ Homework Board) kit. Due to the limited amount of 7-segment LCD displays, I had to get creative on keeping the time. What came of this is the Super Spy Clock!
Here is the code for it:
Post Edited (cavneb) : 9/16/2007 9:48:10 PM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
' This is my first non-book project with the BASIC Stamp Homeword Board and initial kit.
' I was looking at some watches on Amazon.com and found that their Tokyo brand watches were
' all cryptic and cool. I wanted to see if I could make one with my new BASIC Stamp kit.
' Here is what I came up with.
' Define Variables
initial_hour VAR Byte
initial_five VAR Byte
initial_min VAR Byte
counter VAR Byte
five_minutes VAR Byte
minute_counter VAR Byte
hour_marker VAR Byte
hours VAR Byte
' Initialize the 7-Segment LED Display
OUTH = %00000000
DIRH = %11111111
' Set Initial Values for variables
hours = 1
five_minutes = 0
minute_counter = 0
hour_marker = 0
' Main Loop
DO
FOR counter = 0 TO 59
IF (IN0 = 1) THEN
GOSUB ADD_MINUTE
ENDIF
GOSUB DISPLAY_TIME
HIGH 11
PAUSE 10
LOW 11
PAUSE 990
NEXT
GOSUB ADD_MINUTE
LOOP
' Add a minute to the time
ADD_MINUTE:
IF minute_counter <> 4 THEN
minute_counter = minute_counter + 1
ELSE
minute_counter = 0
IF five_minutes <> 11 THEN
five_minutes = five_minutes + 1
ELSE
five_minutes = 0
IF hours <> 6 THEN
hours = hours + 1
ELSE
hours = 1
IF hour_marker = 0 THEN
hour_marker = 1
ELSE
hour_marker = 0
ENDIF
GOSUB TOGGLE_SIX_HOUR_LED
ENDIF
ENDIF
ENDIF
RETURN
' Display the minute LEDs and the 7-Segment Display
DISPLAY_TIME:
GOSUB DISPLAY_MINUTES
GOSUB DISPLAY_HOURS_AND_FIVES
RETURN
' This is the part of my code that I am not too happy with. I tried to create a hash of
' minutes and hours with their respective codes, but I couldn't figure out how to convert
' multiple values into a binary string that OUTH accepts. Here's my version (the long one)
DISPLAY_HOURS_AND_FIVES:
SELECT hours
CASE 1
SELECT five_minutes
CASE 0
OUTH = %00000001
RETURN
CASE 1
OUTH = %00100001
RETURN
CASE 2
OUTH = %01000001
RETURN
CASE 3
OUTH = %10000001
RETURN
CASE 4
OUTH = %00010001
RETURN
CASE 5
OUTH = %01100001
RETURN
CASE 6
OUTH = %11000001
RETURN
CASE 7
OUTH = %10010001
RETURN
CASE 8
OUTH = %00110001
RETURN
CASE 9
OUTH = %11100001
RETURN
CASE 10
OUTH = %11010001
RETURN
CASE 11
OUTH = %10110001
RETURN
CASE ELSE
DEBUG "ERROR"
RETURN
ENDSELECT
CASE 2
SELECT five_minutes
CASE 0
OUTH = %00000010
RETURN
CASE 1
OUTH = %00100010
RETURN
CASE 2
OUTH = %01000010
RETURN
CASE 3
OUTH = %10000010
RETURN
CASE 4
OUTH = %00010010
RETURN
CASE 5
OUTH = %01100010
RETURN
CASE 6
OUTH = %11000010
RETURN
CASE 7
OUTH = %10010010
RETURN
CASE 8
OUTH = %00110010
RETURN
CASE 9
OUTH = %11100010
RETURN
CASE 10
OUTH = %11010010
RETURN
CASE 11
OUTH = %10110010
RETURN
CASE ELSE
RETURN
ENDSELECT
CASE 3
SELECT five_minutes
CASE 0
OUTH = %00000100
RETURN
CASE 1
OUTH = %00100100
RETURN
CASE 2
OUTH = %01000100
RETURN
CASE 3
OUTH = %10000100
RETURN
CASE 4
OUTH = %00010100
RETURN
CASE 5
OUTH = %01100100
RETURN
CASE 6
OUTH = %11000100
RETURN
CASE 7
OUTH = %10010100
RETURN
CASE 8
OUTH = %00110100
RETURN
CASE 9
OUTH = %11100100
RETURN
CASE 10
OUTH = %11010100
RETURN
CASE 11
OUTH = %10110100
RETURN
CASE ELSE
RETURN
ENDSELECT
CASE 4
SELECT five_minutes
CASE 0
OUTH = %00000011
RETURN
CASE 1
OUTH = %00100011
RETURN
CASE 2
OUTH = %01000011
RETURN
CASE 3
OUTH = %10000011
RETURN
CASE 4
OUTH = %00010011
RETURN
CASE 5
OUTH = %01100011
RETURN
CASE 6
OUTH = %11000011
RETURN
CASE 7
OUTH = %10010011
RETURN
CASE 8
OUTH = %00110011
RETURN
CASE 9
OUTH = %11100011
RETURN
CASE 10
OUTH = %11010011
RETURN
CASE 11
OUTH = %10110011
RETURN
CASE ELSE
RETURN
ENDSELECT
CASE 5
SELECT five_minutes
CASE 0
OUTH = %00000110
RETURN
CASE 1
OUTH = %00100110
RETURN
CASE 2
OUTH = %01000110
RETURN
CASE 3
OUTH = %10000110
RETURN
CASE 4
OUTH = %00010110
RETURN
CASE 5
OUTH = %01100110
RETURN
CASE 6
OUTH = %11000110
RETURN
CASE 7
OUTH = %10010110
RETURN
CASE 8
OUTH = %00110110
RETURN
CASE 9
OUTH = %11100110
RETURN
CASE 10
OUTH = %11010110
RETURN
CASE 11
OUTH = %10110110
RETURN
CASE ELSE
RETURN
ENDSELECT
CASE 6
SELECT five_minutes
CASE 0
OUTH = %00000111
RETURN
CASE 1
OUTH = %00100111
RETURN
CASE 2
OUTH = %01000111
RETURN
CASE 3
OUTH = %10000111
RETURN
CASE 4
OUTH = %00010111
RETURN
CASE 5
OUTH = %01100111
RETURN
CASE 6
OUTH = %11000111
RETURN
CASE 7
OUTH = %10010111
RETURN
CASE 8
OUTH = %00110111
RETURN
CASE 9
OUTH = %11100111
RETURN
CASE 10
OUTH = %11010111
RETURN
CASE 11
OUTH = %10110111
RETURN
CASE ELSE
RETURN
ENDSELECT
CASE ELSE
ENDSELECT
' Displays Minute LEDs
DISPLAY_MINUTES:
GOSUB CLEAR_MINUTES
SELECT minute_counter
CASE 1
HIGH 2
RETURN
CASE 2
HIGH 3
RETURN
CASE 3
HIGH 2
HIGH 4
RETURN
CASE 4
HIGH 3
HIGH 4
RETURN
CASE ELSE
ENDSELECT
RETURN
' Clears out the minute LEDs
CLEAR_MINUTES:
LOW 2
LOW 3
LOW 4
RETURN
' This shows whether the hour clock is 1-6 or 7-12.
TOGGLE_SIX_HOUR_LED:
IF hour_marker = 1 THEN
HIGH 5
ELSE
LOW 5
ENDIF
RETURN
[noparse][[/noparse] "What time is it, cavneb?" ]
