LCD AppMod for SumoBot
Hello:
I recently received the LCD AppMod for use with the SumoBot.· Am I correct that the LCD must be mounted horizontally across the breadboard?· If so, the only way to make it fit is to remove all of the circuits I have fine-tuned.· I thought the point of the LCD AppMod was to allow me to test sensors, etc while at a match.· I would be disappointed if I had to remove the components for the circuit each time I needed to test something.
I'm not familiar with the LCD AppMod, but is it physically possible to use an extension cable to place the LCD wherever you choose to?
Bruce Bates
