LCD AppMod for SumoBot — Parallax Forums
LogJam00LogJam00 Posts: 20
edited 2007-09-17 08:08 in Robotics
Hello:
I recently received the LCD AppMod for use with the SumoBot.· Am I correct that the LCD must be mounted horizontally across the breadboard?· If so, the only way to make it fit is to remove all of the circuits I have fine-tuned.· I thought the point of the LCD AppMod was to allow me to test sensors, etc while at a match.· I would be disappointed if I had to remove the components for the circuit each time I needed to test something.
  • Bruce BatesBruce Bates Posts: 3,045
    Mike -
    I'm not familiar with the LCD AppMod, but is it physically possible to use an extension cable to place the LCD wherever you choose to?
    Bruce Bates
