California Dreamin' — Parallax Forums
California Dreamin'
BradCBradC Posts: 2,601
edited 2012-05-04 06:04 in Propeller 1
Ok mobsters, as a bit of a teaser I've attached a _very_ preliminary version of a low-speed USB stack.
I've had to break it into 2 cogs unfortunately (I'm a bit upset about that), but doing it that way just makes more sense when you don't have an interrupt.
This code enumerates as a USB keyboard and types out the lyrics from "California Dreaming" as translated by Michael Hetherington here ...
http://www.sxlist.com/techref/scenix/lib/io/dev/keys/usbdemo-mh.htm
The stack has not been validated, it has bugs and the code is absolutely woeful. I've had my head stuck in 650 pages USB specs all week and not even thought about tidying / optimising any of the code yet.
The advantage of using 2 cogs here is we can properly validate all our inbound CRC's (I've skipped the 5 bit ones at the moment while I build a better checker), and get a response out plus manage *all* possible endpoints.
Most of the embedded stacks face limitations on endpoint management, speed and proper validation. As we run 2 processors for the stack we don't have most of those limitations.
Ignore the :
- bad code (yes I know)
- debug code (it's very hacky)
- typos
- comments written at 3am after half a bottle of Jamesons
- fatal logic errors
- horrid descriptor strings (again, half a bottle of Jamesons at 3am)
Tested on linux and win2k.
I've got improvements and other things in the works. I've learned a hell of a lot about USB in the last couple of days.. but the main thing I learned is that a prop is *just not fast enough* to do Full-Speed.
If, perchance you wanted to run this code up you need 2 68Ohm resistors and a 3.3k.
Plug it into a PC *before* you fire it up as it will enumerate, then about 5 seconds later it will happily type out the lyrics.. then it's game over until you reset the device.
Brad (unicode blows goats)
Why won't the forums allow me to upload a .spin file? I had to add .txt to the end to get it to go! Bah!
[noparse][[/noparse]edit - one of the uploaded files was wrong]
[noparse][[/noparse]edit - IO starts at pin 0 and not pin 1, so 0-2 not 1-3]
Post Edited (BradC) : 9/6/2007 3:21:24 AM GMT
  • Harrison.Harrison. Posts: 484
    edited 2007-09-05 20:07
    This is very impressive, even if it doesn't do more then enumerate as a HID keyboard and type out letters. I'll have to find a worthless usb cable to cut up and use for testing this.
  • BaggersBaggers Posts: 3,019
    edited 2007-09-05 20:21
    Well done BradC, it's one thing I didn't think Prop1 would be up to, but you've done a cracker of a job getting the prop to handle USB [noparse]:)[/noparse]
    Is there anything a prop can't do! I'm beginning to doubt it. well, maybe make a cuppa tea, although some roboteer will probably put that to the test now. lol
    Like Harrison, I'm gonna have to get a spare USB cable, to hack up [noparse]:)[/noparse]
    Jim.
  • BeanBean Posts: 8,129
    edited 2007-09-05 21:31
    BradC,
    Well done ! I was wondering if a Propeller could do this.
    Bean.
    The first rule to being successful is "Learn from your mistakes",
    The second rule is "Be willing to make mistakes"
    www.hittconsulting.com
  • BergamotBergamot Posts: 185
    edited 2007-09-05 21:34
    Well no wonder your code has bugs; you're drinking irish whiskey... [noparse]:)[/noparse]
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2007-09-05 22:28
    Yeah and thats the best of it !
    John Twomey
    Ireland
    'Necessity is the mother of invention'
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-09-05 23:53
    Brad,
    Please check my grasp of your program:
    A prop,
    connected by a generic usb cord [noparse][[/noparse]not a prop plug!]
    to a win pc or linux box [noparse][[/noparse]running a program that expects keyboard input],
    pretends to be a usb keyboard that is typing California Dreaming.
    My real question is this: what references to usb have you found are most useful? And can you share links to them?
    Fred
  • BradCBradC Posts: 2,601
    edited 2007-09-06 03:47
    @Bergamot : I usually drink Scotch, but I had a lovely bottle of Jamesons special reserve that was looking lonely
    @Fred : Absolutely correct. No additional chips, just the propeller, 3 IO pins and 3 resistors
    As for useful docs, these three are all you would need (or all I needed anyway). What made my life easier is I wrote a basic USB analyser based on USB_lowlevel_003.spin (attached above) and used that to watch the enumeration process of a cheapo USB mouse I had lying around. That helped. I have worked with USB HID descriptors before too when playing with Qemu, so I guess that gave me a leg-up.
    HID Class specification
    http://www.usb.org/developers/devclass_docs/HID1_11.pdf
    USB 2.0 specs
    http://www.usb.org/developers/docs/usb_20_071607.zip
    USB in a nutshell
    http://www.beyondlogic.org/usbnutshell/usb-in-a-nutshell.pdf
    Despite the somewhat excessive size, the USB 2.0 spec is absolutely the only document you really need. It answers all possible questions.
    Plenty of people (well, at least 4 given a cursory search) had done this before. 3 on AVR and one on SX.
    I did have a look at Dick Streefland's USBTiny code bit the majority of it is in C and chock full of macros. Made my head hurt. Worth a look if you do AVR though.
    http://www.xs4all.nl/~dicks/avr/usbtiny/
    He does a nice little 4 bit CRC16 routine in there that would be perfect for a memory starved application.
    Shoulders of giants and all that...
    The propeller needs 3 IO pins instead of the usual 2 as it's too slow to boot up on power-on. The USB bus tries to enumerate with it prior to it actually being in a running state, so we use the 3rd pin to do the presence signal when the stack is up and running.
  • deSilvadeSilva Posts: 2,967
    edited 2007-09-06 06:54
    I like the following articles :www.usbmadesimple.co.uk/
    A lot of references on this site: www.lvr.com/usb.htm
    edited 2007-09-06 07:28
    deSilva said...
    That particular site is pretty good. Wish I'd had that last week
    edited 2007-09-06 07:46
    Thanks Brad.
    Post Edited (Fred Hawkins) : 9/6/2007 9:06:08 AM GMT
  • Gerry KeelyGerry Keely Posts: 75
    edited 2007-09-06 08:16
    Whiskey(whisky !) in Irish is UiSce Beatha. Notice the common connection !
    Gerrytongue.gif·
    edited 2007-09-06 12:21
    Nice one there Gerry ... I take it you are from the emerald Isle too then ?
    John Twomey
  • hippyhippy Posts: 1,981
    edited 2007-09-15 17:49
    @ BradC : Just to clarify, is this correct for the hardware configuration ? What does Vusb connect to, if anything ? Am I right in assuming the same connections will be used for your Serial-USB interface ?
                          N/C --<  Vusb
                 ___
        P0 <>---|___|----.----<> D-
                 68R     |
                 ___     |
        P1 <>---|___|----|----<> D+
                 68R     |
                 ___     |
        P2 >----|___|----'  .--> 0V
                 1K5       _|_
       Correct Hardware Configuration
    Edited : Corrected pin numbers to P0..P2
    Edited Again : Pins now selectable in source, 68R plus 1K5, not 680R plus 3K3 as shown earlier. Also 1K5 from P2 to D-, not 3K3 from P2 to P0 as previously shown.
    Post Edited (hippy) : 10/1/2007 12:58:51 PM GMT
    edited 2007-09-15 17:51
    Vusb is not connected anywhere at all. Yep that looks right except they are p0-p2 rather than p1-p3..
    Yeah, the serial-usb uses the same cable and connections.. it's posted up now along with an improved version of the california dreaming code (read with less bugs) [noparse]:)[/noparse]
    edited 2007-09-15 17:57
    I posted just before you delivered your Keyboard / serial code update. Many thanks for both.
    edited 2007-09-15 19:04
    Just BTW: There is a tendency to use "particular" resistor values to pretend a more precise behaviour... I have never ever in all my hobby electronic life used any value other than "E3":
    47 - 100 - 220 - 470 - 1k - 2k2 - 4k7 - 10k - 22k - 47k- 100k - 220k - 470k - 1M
    And I do not plan to use something like 680 or 3k3, or use anything for the video DAC but 220 + 470 + 1k smile.gif
    P.S.: When I look into my resistor box.... 47, 47k and 470k have been also hardly used
  • SkogsgurraSkogsgurra Posts: 231
    edited 2007-09-15 20:26
    BradC - I had just been told that USB cannot be handled like this. Where did you go wrong? - Or were I wrongly informed?? I hope the latter - thanks for a great contribution!!!
    BTW, I got some Wales whisky liquer when I visited swansea this summer. Is that OK to imbibe? Name is "xxx Jones". What else could one expect?
  • Chad GeorgeChad George Posts: 138
    edited 2007-09-16 18:12
    Great work. I too had heard it said that USB was too much for the current prop.
    I know this work is in the early stages, but where do to you "think" it might be able to go?
    Is there any chance of USB host capabilities? Or could we have a USB serial port (even if its at a lower baud rate)
    I've been working on designs for cheap educational robot kits and a software only solution for programming a robot using the USB port (since almost no computers come with serial ports anymore) would help a lot.
    I'd be interested in helping make this happen.
    I know its off topic but has anyone been working on a bit-banging ethernet driver?
    I know I've heard of it being done on other micros.
    -Chad
    edited 2007-09-16 18:53
    Serial? Try here.
    http://forums.parallax.com/forums/default.aspx?f=25&m=216569
    I can get sustained rates of about 6.8-7K bytes/second in both directions simultaneously. I've not benchmarked it in one direction.
    Gonna have a crack at a bi-directional class compliant MIDI interface next I think.
    edited 2007-09-16 20:35
    Chad George said...
    Not to derail this topic, but any links on the other projects that do bit-bang ethernet? I don't know if it's worth it since a spi ethernet chip is about 5 bucks + another 5 bucks for magnetics. The only project I am aware of uses a FPGA and can barely do receive.
    edited 2007-09-17 02:06
    Awesome, thanks for all the work.
    I have a feeling I won't get much real work done tomorrow until I get this working on my robot kit.
    This is really exciting stuff.
    -Chad
    edited 2007-09-17 20:47
    @Harrison & Chad
    I've done some prelim reading on Ethernet.. it _might_ be possible to do transmit, but I can pretty confidently say receive is well out of the Propellers league. If I could do that I could do Full Speed USB (which would be nice)
    10Mhz is just not gonna happen. Hard enough doing NRZI and Bit stuff at 1.5Mhz for USB
  • tpw_mantpw_man Posts: 276
    edited 2008-02-07 20:55
    Can you make a driver that allows the user to send strings on command?
    I am 1010, so be surprised!
  • TracTrac Posts: 7
    edited 2012-04-27 06:32
    Hi Brad, thx for this great code.
    I intend to use your USB generic propeller-keyboard to send makro's and therefore I need for example to send CTRL-C , ALT-F or SHIFT-a to write an 'A'.
    If I now send this line of command $E0,$06 it acts as follows --- press-[CTRL]-release-press-[c]-release --- what results in 'c' instead of 'CTRL-C'.
    Is there a way to include a 'keep key down' code so it can send --- press-[CTRL]-hold-press-[c]-release -- ?
    -Trac
  • pedwardpedward Posts: 1,642
    edited 2012-04-27 11:57
    I would assume that you are sending scan codes as a keyboard, you need to send the proper scan code for the combined CTRL-C.
    Wireshark has a USB sniffing capability which should help you in debugging what the right codes should be.
    edited 2012-04-27 12:38
    I notice in the Keyboard object to use shift or control characters a set value is added to the orignal key value.
    ''      +100    if Shift
    ''      +200    if Ctrl
    ''      +400    if Alt
    ''      +800    if Win
    ''      eg. Ctrl-Alt-Delete = $6C9
    (Delete by itself is $C9.)
    I don't know if USB has a similar type of protocol.
  • TracTrac Posts: 7
    edited 2012-05-02 03:48
    Hi Duane and Pedward,
    I added the keyboard layout for a Generic US keyboard. In Red are the hex scancodes.
    I did 'googled' extended keyboard scancodes but they are not working with this code. Normally it is as Duane mentioned, there are 2 hex codes to be send, but this code is written to send only the 2 last characters and ignore the first.
    This is what I found out.
    ep1send mov out1, #1
    test ep1len, allones wz
    IF_Z mov out1, #0
    IF_Z jmp #ep1send_ret
    call #bufstart
    mov data, #0
    call #pushbuf
    call #pushbuf
    xor ep1toggle, #1 wz
    IF_Z jmp #:keyup 'If you remove this line then the USB keyboard acts is like you hold down a key aaaaaaaaaaaaaaaaaaa
    rdbyte data, ep1buf
    call #pushbuf ' Key down
    mov data, #0
    jmp #:next
    :keyup
    add ep1buf, #1
    sub ep1len, #1
    call #pushbuf ' Key up
    My guess is that there is a bit of code to write to look at the first hex code (ex. $06C9) but my assembler knowledge is almost zero. :innocent:
    1
    2
    3
    4
    5
    6
    7
    8
    9
    0A
    0B
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    err
    err
    err
    A (Q)
    B
    C
    D
    E
    F
    G
    H
    0C
    0D
    0E
    0F
    10
    11
    12
    13
    14
    15
    16
    17
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    I
    J
    K
    L
    M (;)
    N
    O
    P
    Q (A)
    R
    S
    T
    18
    19
    1A
    1B
    1C
    1D
    1E
    1F
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    U
    V
    W (Z)
    X
    Y
    Z (W)
    1
    2
    3
    4
    5
    6
    24
    25
    26
    27
    28
    29
    2A
    2B
    2C
    2D
    2E
    2F
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    7
    8
    9
    0
    Enter
    Esc
    BSp
    Tab
    Space
    - / _
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    3A
    3B
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    Caps Lock
    F1
    F2
    3C
    3D
    3E
    3F
    40
    41
    42
    43
    44
    45
    46
    47
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    F3
    F4
    F5
    F6
    F7
    F8
    F9
    F10
    F11
    F12
    PrtScr
    Scroll Lock
    48
    49
    4A
    4B
    4C
    4D
    4E
    4F
    50
    51
    52
    53
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    Pause
    Insert
    Home
    PgUp
    Delete
    End
    PgDn
    Right
    Left
    Down
    Up
    Num Lock
    54
    55
    56
    57
    58
    59
    5A
    5B
    5C
    5D
    5E
    5F
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    KP /
    KP *
    KP -
    KP +
    KP Enter
    KP 1 / End
    KP 2 / Down
    KP 3 / PgDn
    KP 4 / Left
    KP 5
    KP 6 / Right
    KP 7 / Home
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    6A
    6B
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    KP 8 / Up
    KP 9 / PgUp
    KP 0 / Ins
    KP . / Del
    Applic
    Power
    KP =
    F13
    F14
    F15
    F16
    6C
    6D
    6E
    6F
    70
    71
    72
    73
    74
    75
    76
    77
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    F17
    F18
    F19
    F20
    F21
    F22
    F23
    F24
    Execute
    Help
    Menu
    Select
    78
    79
    7A
    7B
    7C
    7D
    7E
    7F
    80
    81
    82
    83
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    Stop
    Again
    Undo
    Cut
    Copy
    Paste
    Find
    Mute
    Volume Up
    Volume Down
    Locking Caps Lock
    Locking Num Lock
    84
    85
    86
    87
    88
    89
    8A
    8B
    8C
    8D
    8E
    8F
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    Locking Scroll Lock
    KP ,
    KP =
    Internat
    Internat
    Internat
    Internat
    Internat
    Internat
    Internat
    Internat
    Internat
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    9A
    9B
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    LANG
    LANG
    LANG
    LANG
    LANG
    LANG
    LANG
    LANG
    LANG
    Alt Erase
    SysRq
    Cancel
    9C
    9D
    9E
    9F
    A0
    A1
    A2
    A3
    A4
    A5
    A6
    A7
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    Clear
    Prior
    Return
    Separ
    Out
    Oper
    Clear / Again
    CrSel / Props
    ExSel
    E0
    E1
    E2
    E3
    E4
    E5
    E6
    E7
    224
    225
    226
    227
    228
    229
    230
    231
    LCtrl
    LShift
    LAlt
    LGUI
    RCtrl
    RShift
    RAlt
    RGUI
