Connecting multiple BOE / Proto Board to set of sensors and servo motors
Hello,
I have a BoeBot and want to mount the Propeller Proto Board on top of the Stamp BOE
because I would like to be able to quickly switch between BS and Prop. programming.
I'm looking for a solution to quickly switch all sensors and motors from one board· to the other.
Solutions already proposed by D. Faust: (thread "Mapping concept" in Sandbox)
What if you just run all of the wires to both processors and have a switch disconnect power from one or the other.
I find this·a tricky one because there is the risc that both boards become switched on by mistake or during
transition from from board to the other .. what will happen with the I/O's ? Did read already a lot about damaged
pins.
Solution already proposed by Dgswaner: (thread "Mapping concept" in Sandbox)
Skywalker I know they make Single pull and 10 throw switches +/- why not incorporate a few of those switches Or perhaps a multi pin plug for all of the connections and you just plug in which ever CPU you want to use.
I'm not sure what these switches are but I'm looking for an elegant solution, one switch which triggers a multicontact relay or something like that.
Does anybody have some experience / proposals .. DO or DON'T tips ?
Thank you,
Ed
pins.
Thank you,
Ed
LOOKDOWN ThisThread, [noparse][[/noparse]Your_?, My_?, Cool_Thing], looknum LOOKUP looknum, [noparse][[/noparse]1, 2, 3], subnum ON subnum GOTO Hope_this_helps, Thanks!, WOW!! END
Thank you,
Ed
Yes, that is an option. A safe option. Dgswaner suggested the MPP (Multi Pin Plug) which is basically the same.
thx, Ed
