What's your favorite transistor/MOSFET for general use?
I need to re-stock my bench. My 25 year old bag of 2N2222s I bought at the TRW swapmeet has come to an end. I've lived with them for so long, do I need to change? I'd like to move to MOSFETs.
I need some normal current .2A to .5A TO-18/TO-92 stuff. (pull relays, etc. etc.) to replace 2N2222???
And some higher current, around 5A to 10A TO-220 package.
So, your breadboarding something and you need a device. What do you reach for?
A 2N2222, a BS170 or a 2N7000? What is it?
and for more power, what? a IRLZ43, or IRL520?
So, what in your parts bin right now? And what does your hand reach for first?
Normaly 9 - 15 volts supply, pushing them with 5 volt logic.
Thanks, Chris
I'm not scared of your robot. I'm covered by Old Glory (youtube)
Thanks, Chris
There's nothing like a new idea and a warm soldering iron.
Chris I.
Thanks again, Chris
I use the BC546 (plastic) which doesn't have as good a spec as the good old 2N2222. I've got a thing about putting jam cans on my pcbs.
PN2222 (the plastic 2N2222) are not always available here.
John
That really points you back to the 2N2222 for almost anything. I suspect the primary reasonfor using the MOSFET is less wasted power. So it might fit more comfortably into a finished project.
Once a project is complete with components soldered in place, the MOSFETs tend to be protected unless they are wired directly to interfaces.
For really high power applications, usually you risk stocking the wrong device. I'd still to the 2N2222 and its compliment. [noparse][[/noparse]Is that the 2N2904?]
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
I also keep plastic and T-03 versions of 2N3055 and MJ2955's for power work (Cheaper than mosfets in some cases)
Pete
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
