Using mouse driver v1.1 with Hydra? — Parallax Forums
mparkmpark Posts: 1,336
edited 2007-09-09 10:29 in Propeller 1
Is it possible to use the v1.1 mouse driver with the Hydra? I'm used to using mouse_iso_001, which takes a pingroup parameter. The 1.1 start method wants two parameters, dpin and cpin, and no values I've tried have worked. Help?
  • deSilvadeSilva Posts: 2,967
    edited 2007-09-08 18:27
    The Hydra has a totally different interface to the PS/2 connectors as Parallax's later boards. Have a look at the schematics!
    Mike intended to make a "compatible" driver for Mouse and Keyboard....
    You will find that the keyboard software has similar restraints as it is also a PS/2 interface.
    The pin number are different and there are twice as many pins involved with driving the PS/2 interfaces.
    Essentially, Anton was more conservative in designing the circuitry due to that fact that he drives the Hydra at a higher speed, 10Mhz Xtal.
    Nothing wrong with being conservative.
    "Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
    ···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
