Using mouse driver v1.1 with Hydra?
Is it possible to use the v1.1 mouse driver with the Hydra? I'm used to using mouse_iso_001, which takes a pingroup parameter. The 1.1 start method wants two parameters, dpin and cpin, and no values I've tried have worked. Help?
Mike intended to make a "compatible" driver for Mouse and Keyboard....
The pin number are different and there are twice as many pins involved with driving the PS/2 interfaces.
Essentially, Anton was more conservative in designing the circuitry due to that fact that he drives the Hydra at a higher speed, 10Mhz Xtal.
Nothing wrong with being conservative.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
