LED cube
I don't know what microcontroller they used for this LED cube project, but it's very doable with a propeller.
uk.youtube.com/watch?v=lFDcdN47V5s
Help to build the Propeller wiki - propeller.wikispaces.com
P.S. I believe that Bre meant a 470 Ohm resistor rather than a 47 Ohm resistor.
470 Ohms (Yellow, Purple, Brown)·sounds about right if you are using a 5V supply and the LED's are roughly 7mA
...use a 220 Ohm resistor (Red, Red, Brown) if you are driving this from a 3.3V Propeller.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 9/7/2007 7:16:53 PM GMT
Graham
Graham
Beau Schwabe
IC Layout Engineer
www.maxim-ic.com/appnotes.cfm/appnote_number/1880
This scheme must be driven with open collector·HIGH for each segment, and then driven·LOW for the Common Cathode (CC)·character of interest in order for it to work properly.
Beau Schwabe
IC Layout Engineer
Post Edited (Harrison.) : 9/7/2007 7:32:21 PM GMT
