LED cube — Parallax Forums
LED cube
CardboardGuruCardboardGuru Posts: 443
edited 2007-09-07 18:57 in Propeller 1
I don't know what microcontroller they used for this LED cube project, but it's very doable with a propeller.
uk.youtube.com/watch?v=lFDcdN47V5s
Help to build the Propeller wiki - propeller.wikispaces.com
    edited 2007-09-07 18:04
    With 6 level's that would make a cool LED clock.
    P.S. I believe that Bre meant a 470 Ohm resistor rather than a 47 Ohm resistor.
    470 Ohms (Yellow, Purple, Brown)·sounds about right if you are using a 5V supply and the LED's are roughly 7mA
    ...use a 220 Ohm resistor (Red, Red, Brown) if you are driving this from a 3.3V Propeller.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 9/7/2007 7:16:53 PM GMT
    edited 2007-09-07 18:22
    There was talk about a different kind of multiplexing (called someonesname-plexing) a few weeks ago that would allow many more leds than the expected to be lit from a given number of outputs, considering that the propeller has 32 IO you could make a seriously cool cube and have leds chasing each other around like flies. I'd use smt leds glued to mylar sheets and connected up with super fine magnet wire, mount in a frame and "jobs a good un"
    Graham
    edited 2007-09-07 18:27
    It was charlieplexing and allows n^2-n leds to be controlled so thats 992 just short of a 10X10 cube. Not quite as good as I imagined (forgot about the cube bit!)
    Graham
    edited 2007-09-07 18:34
    I don't know if it's "charlieplexing" (...I'd never hear that term before this forum) or what, but if you implemented polarity reversal rather than just HIGH/LOW to control the LED's, you can effectively double the amount of LED's you could control·with the same·number of I/O lines you would use otherwise.
    Beau Schwabe
    IC Layout Engineer
    edited 2007-09-07 18:51
    Yeah ok...
    This scheme must be driven with open collector·HIGH for each segment, and then driven·LOW for the Common Cathode (CC)·character of interest in order for it to work properly.
    Beau Schwabe
    IC Layout Engineer
  • Harrison.Harrison. Posts: 484
    The processor is an Atmel ATtiny2313. The minipov kit schematics are at: http://www.ladyada.net/make/minipov2/hardware.html .
    Post Edited (Harrison.) : 9/7/2007 7:32:21 PM GMT
